Just wondering if anyone knows which company makes the dominator 66 or if the only place to get it from is Beans, and if it can be found off of another vehicle
I could tell you, but I won't do that to Bean, he developed it and took the risk to bring it to market, he should get the business. He does tons to help us all as well .
Diesel Mechanic 28 yrs
In function it has the same effect of changing the ratio between the exhaust turbine and the compressor. Tom's 1.0 housing on the stock compressor drives the compressor harder by making the exhaust fit through a smaller "nozzle" to turn the turbine. This changes the ratio between the the two. With the d66, Bean makes the compresor wheel 6 mm bigger thus changing the ratio, but by going bigger overall. Kind of the same effect as a 1.0 on the stocker but capible of more flow. IMO anyway....
<span style="color: #FF0000">#18</span> not all trucks are created equal
THE COWBOY'S CADILLAC,<span style="color: #FF0000">my pics.</span>, 96 F-350 XLT SC DRW PSD, 4x4 conversion(D60),more oil than you, auto tranny by faubion motorsports, tuned by a backwoods hack(thanks tony), 230cc injectors, D66 turbo, head studs, 910 valvesprings, open element intake, homebuilt fuel system, 3-4"DP, intercooler with homemade spider and piping, 5" chrome stacks with turnouts, front hitch(for my weight bar), member of the <span style="color: #FF0000">WNYPA</span>
One way is to weld one into the compressor housing like This
that would be the exhaust/turbine housing. just wanted to clarify so people wouldn't get to confused.
how would a wastegate be added to the dom66?
[/ QUOTE ] [ QUOTE ]
ATS has one but it is a .95 housing not a 1.0 for qiucker spoolup
Be careful here....there is some science and math involved. DarthStroker is experementing with this Idea, but he has had turbo stall which can be be very destructive. There are limits. Remember the ratio idea 1.0 on stock turbo has the same "ratio" to the compressor as 1.15 on the 66 mm compressor on the D66. When you go 1.0 or .95 with the 66mm compressor, you are really overdriving the compressor. Darth is still experimenting on his set up.
Don't give me too hard of a time, but I am working on my PhD in math. If anyone needs some complicated math figured out, get in touch with me and I might be able to help. Then again, a lot of these exhaust problems [like what is the best shaped downpipe] are pretty complex fluid mechanics problems that no one really knows the answer to.
Kurt
SOLD!!
1997 F350 XL PowerStroke 4WD, ZF-5 w/ South Bend Con OFE Clutch
Regular Cab, Long Bed, SRW, 3L55's, Bilstein shocks, Warn premium hubs
3-inch downpipe/4 inch exhaust w/ Magnaflow muffler and cat
Tymar intake
International Water Pump with integrated filter
Wildman Four-Position Chip; Baby Swamps; D66 turbo with 1.00 housing; SD HPOP
Isspro EV Boost and Pyrometer gauges
285/75R16 E-Rated BFG All Terrain KO's
Rear Disc Brakes from Blackbirds Custom Trucks Pictures of it all...
