Double Clutch System? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-26-2009, 11:43 PM   #1 (permalink)
benblitch's Avatar
Okay so a buddy of mine has a double clutch on his Dodge and I am wondering what the possibility is of putting one on my 1996 F250 5spd. I have a 4:10 in the diffs right now and do about half highway long distance driving and half work truck heavy lifting. A DCT seems like the perfect solution. Any thoughts or recommendations?
'96 PSD 5spd. 6637 Intake, Manual Lockers, Bigarse bumper w/ Warn 12000lb wench. 250K and running Tough.
benblitch is offline
Old 02-27-2009, 08:08 AM   #2 (permalink)
Mark Kovalsky's Avatar
What is a double clutch? I've never heard of it. What does it do?
Mark
Mark Kovalsky is offline
Old 02-27-2009, 08:35 AM   #3 (permalink)
Is he talking about a clutch system with 2 disks?
macmaniac1 is offline
Old 02-27-2009, 09:25 AM   #4 (permalink)
or maybe there is some misunderstanding that he is doubleclutching his truck. which is just a different way of changing gears, push the clutch once and put the tranny in neutral, push the clutch again and place it in the next gear. Or maybe he is just pulling on your leg......LOL
Somedays its just not worth chewing through the restraints
2011 F350 CC lariat ultimate dually with nav, line x, more mods comming
Y2K 4x4 250 PSD Xcab, auto, way too many mods to list Broken March 2011, written off due to collision
Crazy_Canuck is offline
Old 02-27-2009, 09:42 AM   #5 (permalink)
Or maybe he means an add on overdrive unit. It's impossible to say from what is in his post.
Mark
Old 02-27-2009, 09:45 AM   #6 (permalink)
benblitch's Avatar
Hi gear and Low gear transmission
I am talking about a Hi speed and Low speed transmisison like on a semi. Maybe you guys know a better term for it. There is a pull lever on the gear shift that transfers the shifting to a second clutch. Am I totally off?
Semi-trailer truck - Wikipedia, the free encyclopedia
Old 02-27-2009, 10:16 AM   #7 (permalink)
Dollrider's Avatar
My Photos: (5)
I believe your talking about a range selector, can either be a range selector in the tranny or a 2-3 speed rear-end. It doubles or triples (depending on how many ranges) the amount of gears you have in the transmission.
’97 F-250HD, PowerStroke, E4OD, 4.10 LWB x-cab Hypertech Programmer, Tymar style intake, Banks DP, Banks Boost and tranny time gauge, Insspro Pryo, Insspro Turbo Temp monitor, BFG 285/75/16, exhaust brake, Headache Rack, spray in Ryno lining, Wilson Truckers Cell antenna, Ford AIC 14x,k. Coming Soon, Dana 60! http://photos.thedieselstop.com/show...=63546&thumb=1
Vol. Firefighter 2 years and running!
'95 E-350 PSD, all stock, just replaced trubo and IDM 306K and runs strong.
'78 IH 1950B Dump Truck, Cat 3208 N/A, Air gate, 5 speed/ 2 speed rear-end, air brakes.
Dollrider is offline
Old 02-27-2009, 10:46 AM   #8 (permalink)
You are talking about an add on overdrive unit. I've never heard called a double clutch.
US Gear makes one that will fit your truck. Gear Vendors is another company that makes one.
Mark
Old 02-27-2009, 12:38 PM   #9 (permalink)
My Photos: (60)
Double clutching is a technique for shifting non-synchronized transmissions. Twin disc clutches have two discs with an intermediate pressure plate between them. This gives you the ability to handle more power and torque.
The button or small lever you refer to is a range selector on a truck transmission.
You can also have a second transmission that gives you more gears, as noted the Gear Vendors or US Gear units are the most common.
What your friend probably has is either a Gear Vendors or US Gear overdrive or underdrive unit. With the final drive ratio you have what you are after is an overdrive unit.
LINK TO GEAR VENDORS list of Ford 4x4 applications.
LINK TO US GEAR applications list, pricing is at the bottom if you scroll down.
Hope this gets you going.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 02-27-2009, 01:58 PM   #10 (permalink)
benblitch's Avatar
You guys rock...
Now that all of that is cleared up. THANK YOU.
Old 02-27-2009, 05:31 PM   #11 (permalink)
he is talking about a dule disc clutch check southbend clutch or valair. valair will be the cheepest..
96 powerstroke 7 inch lift,35in tires, cold air intake,4in exhaust 6in tip.DIY stage1 DP-Tuner 2001 superduty axels.
Fdturbobrando is offline
Old 02-27-2009, 05:44 PM   #12 (permalink)
My Photos: (60)
If you check the whole thread he is talking about a two speed auxiliary transmission like his friend's Dodge has. He is not talking about double clutching a non-synchronized transmission nor is he talking about a dual disc clutch.
