Old 01-13-2006, 06:27 PM   #1 (permalink)
My Photos: (22)
Downpipe ? for '97
Trying to help a buddy out. '97 F350 7.3 CC/LB 4x4, manual tranny. We are looking to do a complete turbo back exhaust on his truck. Where can I get an exhaust for this truck, and what is the biggest downpipe without major modification.
Thanks,
RG
Early'99(11/98) F-250 XLT swb,CC,4x4,HX hose,in-tank/PP mod,Poontank,Tymar Intake, 4"turbo back straight piped, DP-Tuner PMT1w/80hp eco,BTS tranny, 4"DR,35"x13.5x20 Toyo AT's on 20x9 IceMetal 889's,250K & going strong!
Garza is offline
Old 01-13-2006, 06:54 PM   #2 (permalink)
Re: Downpipe ? for '97
Ive heard of some guys putting in 4 inchers with some work on the firewall, for me squeezing in a 3in was enough cursing and tool throwing [img]/ubbthreads/images/graemlins/shocked.gif[/img]. I got a nice exhaust from gofastengineering.com or checkout gtsmotorsports, beansdieselperformance, or ebay
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 01-13-2006, 07:33 PM   #3 (permalink)
WormDrowner's Avatar
Send a message via ICQ to WormDrowner
It also depends on how your cab is mounted. BigDan97 says he had trouble getting his 3" in place but my 3" dropped in perfectly with no modifications to the firewall at all and I have a small amount of clearance still to boot!
"You can all go to Hell. I'm going to Texas." - Davy Crockett
1996 F-250 Supercab PSD with Edge Evolution, Grand Rock Powerflow 4" exhaust, AFE Stage II Intake. Isspro Gauges.
1996 MB C220
WormDrowner is offline
Old 01-13-2006, 09:21 PM   #4 (permalink)
my guess is that you have an auto and bigdan97 has a stick. ive heard it sucks to put a downpipe on a stick, but its not as bad on an auto because you have a little more room.
1997 F-350 Powerstroke XL Reg cab long box 4x4 5 spd. with 3.55's
3' downpipe then 5' straightpipe, TS 6 pos chip, Autometer Ultra-lite egt-boost-fuel pressure gauges, BFG Mud Terrains, xlt seats, more to come [img]/ubbthreads/images/graemlins/smile.gif[/img]
pictures- http://photos.yahoo.com/badpowerstroke
BadPSD is offline
Old 01-13-2006, 09:57 PM   #5 (permalink)
I shouldnt really claim it was that bad, I was trying to bend in the actual firewall instead of just the pinchweld [img]/ubbthreads/images/graemlins/blush.gif[/img], but it still sucked, Ive done one more automatic since then and it still wasnt that fun but I have an auto so ill butt out of this one i didnt know its different.
Big_Dan97's Photos
Old 01-13-2006, 10:52 PM   #6 (permalink)
I just did a full turbo back and intake in my 97 F250. I did it by my self in 4 hours in the parking lot my my apartment in a greasy parking spot. If you call dale at Tymar (you can find his website on the interent) he will hook you up with what you want.
I would recomend a gutted EBPV, do a search in the archives for that its a 1 hour job. Behind I would recomend a 3x4 inch downpipe, because it expands sufficently but only requires bending of the spot weld seam in the firewall. Behind that I would recomend a 4 inch out the back, delete the cat. Your EGTs will be lower and you will have more power(a somewhat useless term) and torque throughout the power band. If you go to NAPA and get one 3 inch easy seal clamp and five 4 inch easy seal clamps you will have pretty good luck getting done what you need. A sawsallwith some 8 inch rescue blades and a 4 ton porta power from habor freight will be a good investment in your time. You can use it to cut off the cobra head from your stock DP and cutt the ends off the stock hangers (leave the rubber parts) to drop your old exhaust.
Call Dale. you wont be dissapointed.
with 2 people it wont take much time at all.
1997 F-250 PSD Tymar Open Air, Full Set of gauges, 3x4 DP to 4inch stright pipe out the back, Edge EVO,RAM Mounts Universal Lap top mount. Hardwired Holux GPS 310 Sensor. Super cooling, Offroad handling package, TOTALLY REBUILT XMISSION to the TUNE of $3112.23 (not by choice)as of July 28th. 125 Gal AUX fuel tank in the bed(workin on WVO application for it)
mlnelson is offline
Old 01-13-2006, 10:58 PM   #7 (permalink)
My Photos: (9)
How did you hang your new exhaust? Did you have to weld it to the stock hangers?
2002 F-350 crew cab, DRW PSD 4x4 automatic. 158,000 miles, Ford AIS, otherwise completely stock.
'94 2WD F-250 PSD 5 speed. 302,000 miles, DIY open intake, 5" single stack, Banks pyro and boost gauge, Grover air horns, DynaMat. Still on the original CPS!
Foxx is offline
Old 01-15-2006, 02:55 PM   #8 (permalink)
Garza,
Take a look at the MBRP systems, they are available in aluminized and stainless. The down pipe is 3 inches and then at 22 inches from the turbo it changes to 4.0 inches. This is the fastest transition I know of to get to 4.0 inches as fast as possible. Otherwise you'll have to really really modify the firewall. Call us if you have any questions etc.
Mark @ DPPI
DIESEL PERFORMANCE PARTS INC. 1-866-455-7788 www.DIESELPERFORMANCEPARTS.COM GUARANTEED PRICES DISTRIBUTOR of MBRP & AFE EXHAUST, EDGE PRODUCTS, SMARTY, AUTO METER, ISSPRO, & DiPRICOL GAUGES, SUPERCHIPS, PREDATOR by DIABLO, AFE FILTERS & INTAKES, PML TRANNY PANS & DIFF COVERS, ARP, FLUIDAMPR, POWERSLOT & HAWK, TS PERFORMANCE, BULLY DOG, AIR DOG FUEL SYSTEMS, BOSCH, SUNCOAST, STANADYNE AND MORE.
Mark Craig is offline
Old 01-16-2006, 05:07 PM   #9 (permalink)
stroker101's Avatar
would a body lift kit help with gaining more clearance for dp installs?
97 F-350 XLT*7.3L PSD*2X4*BLK*CC*DRW*E4OD*4.10 Gears*Alum. Whls*TYMAR HX mod*Open Air Intake(Tymar copy)*LONG Tru-Cool Trans Cooler #LPD47391*3" DP* Magnaflow 4" S/S exhuast w/5" polished S/S tip*TS-Perf. 6-position chip*Hide-Away Gooseneck hitch*LT235/85R/16*3GA.Pillar Pod/ISSPRO(exh.temp,tranny temp,turbo boost)*Billet Grille*SMITTYBILT Chrome Step-bars*
06' Dodge Ram HD 2500,SLT,4x4,Wht,Quad cab,5.9L CTD,short box,5" Magnaflow exh. w/6"tip,35/12.5-17" BFG M/T,Cool Hose(blk),DTR intake elbow,K&N filter,Dash mounted ISSPRO ga.(boost,pyro,tranny),Tuff Country 2.5" lvl kit,Rhino whl-whl step bars,Rhino liner
09' YZ250Y/ #683(blue) 2-smoke
08' YZ450FX/#101(white)
08' YZ250FX/#110(white)
07' Yamaha Grizzy 700FI 4X4 (28" mud bugs)
07' 18' Work and Play cargo trlr(7780lbs GVWR)
06' 18' car hualer
stroker101 is offline
