Old 06-09-2007, 11:17 PM   #1 (permalink)
downpipe question
Hello everybody, new member and 7.3 owner. Wanting to install new downpipe and I'm not sure whether to try to do it myself or not. one muffler shop in town wouldn't touch it and the other wanted $450 bucks JUST to install it! Is it that hard to install a 3 or 4" downpipe on a 95 4x4 psd? Thanks for any help you can give me.
01bluegrass is offline
Old 06-09-2007, 11:50 PM   #2 (permalink)
Re: downpipe question
Congratulations on several points.
-Welcome to this site.
-Congrats on the truck.
-You just found several places never to take your truck to again.
The downpipe isn't hard. The old one is easiest to take off in pieces, see pic. BTS cut mine from underneath with a sawzall and a long blade.
They used a piece of exhaust pipe (heavy stainless) to bend the pinch weld back to clear the new pipe. Some other people like to use a porta-power, 2x4, or a scissor car jack.
Probably 1 to 1.5hrs if you're used to working on your own vehicles. Add an hour if not. I would have done mine myself, it was a matter of going there anyway for a chip, and I'm glad I got it done at the same time. I'd hate to know what my EGTs would have been w/ the stock downpipe.
Daniel
'96 F250 XLT, PSD, 4x4, ExtCab, LB, Auto, 3.55.
11-06: DIY Open Element, EBPV & TC exhaust brake.
02-07: 40 gal '05 F550 aft-axle tank = ~60 gal total.
03-07:DIY/RDS stage 1's, 220,356mi, BTS downpipe & 6pos chip.
04-07: 226,000mi 277HP, 543TQ, Graph
05-07: EGT, Boost, Trans from Tymar
06-07: 4" exhaust, 31 row 6.0L trans cooler
08-07: BTS Transmission.
09-07: 80.76 @ 16.527
My picture & diagrams
danjreed is offline
Old 06-10-2007, 12:00 AM   #3 (permalink)
Thanks for the help Daniel. Did you install a 3 or 4" downpipe on your truck?
Old 06-10-2007, 12:25 AM   #4 (permalink)
BlueMule's Avatar
My Photos: (12)
Hey dopper
Welcome to TDS [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] <font color="green">HERE</font> is a web page that gives you an idea of what's involved in doing a downpipe.
When I did mine I used a 12" bimetallic demolition and rescue blade in the sawzall and made just one cut from up above after detaching the DP from the cat and turbo. Pull the pipe up as far as possible and make the cut as low as you can and the bottom half should drop out the bottom with no problem. I didnt have a porta power so I used a 6' length of #10 rebar and just pushed the firewall back using the head as a fulcrum point. There is a fuel fitting on the rear of the head so be carefull if you pry against the head.
BlueMule is offline
Old 06-10-2007, 01:06 AM   #5 (permalink)
Thanks Rodney. That's a huge help! I appreciate all the info. I still didn't catch what size downpipe to go with. Will a 4" fit or is there much difference as far as making the room with a 3"? Thanks again guys.
Old 06-10-2007, 02:11 PM   #7 (permalink)
As Rodney said, 4" is a pain. Mine is 3".
danjreed is offline
Old 06-10-2007, 03:30 PM   #8 (permalink)
Thanks for the advice guys. I think I'll go with the 3". I don't think I have the patience to try to beat in a 4"
Old 06-10-2007, 04:07 PM   #9 (permalink)
Call Dale at tymar and get the 3 into 4 inch model, My 95 didn't require much...very little massaging to get it to fit. Just cut from the bottom up on the cobra head and mine fell right out. 2 12inch sawzall blades and I was good to go. Don't let it intimidate you. You can do it..now get to cuttin.
95 CCLB 4X4, DP, TYMAR, 5POS CHIP, 4",3 GUAGE POD, 115k, 265/75/16 bfg E, E4OD,4.10s,Putnams hitches front and rear,Air bags rear.
realbadlarry is offline
Old 06-10-2007, 10:52 PM   #10 (permalink)
BEECHBM69's Avatar
If I can do it......anybody can do it.......bruises and all...... [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Dan
97 F250, SC, LB, 4x4, 7.3 PSD,E4OD, 4.10, Autometer Gauges Warn Manuals, Tru-cool 4590. Tymar Intake. Super Duty Driving Lights. 285/75/16 Pro Comp A/T's, DIY Tow Hooks.Canvas Soft Topper. DPP downpipe. A work in progress.pics
BEECHBM69 is offline
Old 06-11-2007, 12:12 AM   #11 (permalink)
LabRat's Avatar
Dan
It's do-able but not easy! I struggled for most of a day to get a 3" to fit. A duck bill on the end of a porta-power was still not easy. Be careful - I could actually see the cab go out of square when using the hydraulics to move the firewall. Move it farther than you think or you'll get some grinding as the the truck goes over uneven ground.
1997 F350 7.3L PSD; LB; SRW; Crew cab; RSK with dual front Bilstein shocks; Banks PowerPack; E40D with BadBoy converter & shift kit; 3" DP with 3.5" back; Airlift air bags; Mag-Hytec diff/trans covers; Power Slot rotors; Flex-a-Lite remote trans cooler; Tymar intake & CCV mod; SPDiesel SSEBTC controller; B&W turn-over ball & Companion 5th wheel hitch.
Homepage: http://community.webshots.com/user/rmrusten1
LabRat is offline
Old 06-11-2007, 10:10 AM   #12 (permalink)
Just one more question before I order my downpipe-Will the factory exhaust system from the downpipe back be ok or will a 4" exhaust make a huge difference? It has a straight pipe now-that way when I bought the truck. Just trying to decide if to spend the extra $300 for a complete system or put that extra money on guages.Can't do both- Gotta keep the better-half happy [img]/ubbthreads/images/graemlins/grin.gif[/img]
Old 06-11-2007, 02:37 PM   #13 (permalink)
Gauges. Definately gauges.
danjreed is offline
Old 06-13-2007, 06:00 PM   #14 (permalink)
Im installing my downpipe now and I've bent and pulled for all the space i can get but I still think its going to rub at the bottom of the firewall. Is this ok are does their have to be space between the pipe and firewall/floorpan?
Old 06-13-2007, 06:15 PM   #15 (permalink)
There has to be space or it will drive you nuts....ask me how I know
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
