anyone else have this problem?i thought it was rubbing against the tranny so last weekend i installed a strap to bring it closer to the frame rail...worked for like a day and now it rattles worse than ever! how did you guys deal with this?
mine is tight against the tranny and I have no noises. My guess is you are hearing it rub on the cab? If so, you have to make a bit more clearance at the pinch weld..
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
i am pretty sure its not the up-pipe. i can hear that stupid noise coming from the floorboards. its just brutal when i shut her off. by the way, does the tymar intake make a noise difference? mine came in the mail but i haven't gotten a chance to install it yet
