I wanted to let you guys know that I have a DP chip in the mail so I can do some testing. I have a Wildman chip now, and I am going to compare the pro's and con's of each tuner. I am not doing this to persuade anyone either way, but I won't to know how they compare. I will also be doing some dyno runs with each chip and see how they compare. If you would like to me test something then let me know so I can do it. I hope to write a good tech article for the comparison's. Thanks
Reuben
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Definitely interested! I will be buying a chip within the next month and havent made up my mind yet.
__________________ 1997 F250 XL 2wd 5spd 7.3 , SRW ,ext cab, Tymar air intake, 3"DP with 3" straight pipe, No cat or EBPV, "A" pillar gauge set with Auto-Meter Pro-Comp boost and Pyro, 265/75-16 with stock steel wheels, Custom conversion van bucket seats with custom console holding SFF PC with GPS and MP3
Ya I'm hoping to get some solid data from my testing of the two chips. I will dyno the truck, and tow quite a bit so I should have a good time nonetheless.
Depending on how long ago or where you bought the TW chip from you might consider getting it updated.
Ben
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Yup i just got a new tune from Tony bout month or so ago and it runs lots better than some i have gotten bout 6 months ago.
1996 crew cab 4x4 black psd BDP 250cc hyrbids BDP fuel system Stealthhinator dual ipr hpop
H2E TDP tuning 515hp 1158tq
99.5 psd reg cab 2wd
334hp 740tq
rdrcm #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke Truck and misc pics
can you get TW tunes on an f5 chip? Looking forward to the review!
__________________ 1996 F250 X-cab SB, zf-5, open element intake, tymar 3-4" DP, 4inch dual DE exhuast,gutted EBPV,MidWest Shortshift kit, DP-tuner chip,Gauges,
sounds, with a bunch of rammat and ensolite in the cab.
1997 f250 longbed xcab,zf-5, 4inch lift with 18 inch wheels and mickey thompsons
Motor all stock for now..
1994 f250 with a custom dump/flatbed heavy duty winch up front, 7.3 idi, None turbo...
ok i've heard that on my stock truck with a dp all the settings over 100 hp the truck will bog down or something like that. is this true. what else will it do? if on 140hp will it smoke like they say it will but be a turd at the same time? and will the tony wildman do the same thing? i just want to do what will be the best.
1996 f250 4 inch lift, 35BFG AT's, 16" eagle alloys, banks transcommand, autometer boost, pyro, trany gauges, sirius radio, plan to get a dp tuner or TW chip, i cant decide.
Ben
I just wanted to let everybody know that the tunes I have from Wildman are about 2 years old, and they need to get updated. So for the testing to be valid, I will get some of Wildman updated tunes to make it fair.
