How hard is it to drop an auot? my truck got totaled and im buying it back so i can get the tranny out for my new 96. what are the steops to taking it out and is it that difficult?
-Kord
( totalled)white and turquise 96 with 175,000 miles. 4 in lift with 16 in welds and 35 in bfgs. 5in straight pipe exhaust, twildman 4 postion, pyro and boost gauges, diy tymar, Built Tranny. new turck white 96 130,000, 4 in lift, 35 in tires, 4 exhaust, intake, gauges, tw 4position and built tranny
Just did this, youll want a tranny jack, much safer, youll need at least one helper if youre gonna keep your tcase on. You undo driveline, take off the crossmember, undo bellhousing bolts, TC to flywheel bolts and slide her out. flywheel wrench would be handy. It looks like you have to undo the starter but you dont, also the tranny dipstick just popped right off if I remember right. youll want some long extensions, its not too bad, might be good to have a chiltons or a right up off here to go in the right steps.
Dan
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake Big_Dan97's Photos
You can drop it with a helper in about 30 minutes. You need about three feet of a 1/2" drive extensions and a universal to make it easier to get the top bell housing bolts out. The hardest bolt to remove was the dip stick tube bolt on the back of the head. A trans jack is well worth the money!
1995 F-350 XLT DRW
212,000+ miles
3" down Pipe
4" AFE Exhaust
No muffler
DIY TYMAR
DIY IDM mod
DIY Injectors
DIY Water Injection
DIY HPX
BB mod
Tony Wildman Chip
17* HPOP
6.0 IC
HID headlights
Gauges: Pyro, Boost, Trans John Wood Trans with a 6.4 T/C Truck Pics
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rudolf_Diesel</div><div class="ubbcode-body">You can drop it with a helper in about 30 minutes. You need about three feet of a 1/2" drive extensions and a universal to make it easier to get the top bell housing bolts out. The hardest bolt to remove was the dip stick tube bolt on the back of the head. A trans jack is well worth the money! </div></div>
The 2 on the top can be gotten from the top. It hurts and is rather difficult, but it can be done.
You don't need 3 feet a swivel is a must if you don't. You can also use a regular jack with some modification. You can also lower the tail housing to gain better access to the top bolts. You can leave the bolt on the block for the dipstick. Just as you start to lower the trans make sure you pull the slip joint apart. Also up-pipe donuts can be very easily replaced when its out.
awsome thanks for all the input. Does anyone know if there is a right up on here? or if not where i could get one?
-kord
