im sure this has been answered already, but will the dt466 cps that is being talked about so much in the super duty forum work in our trucks? i know they changed the connectors in 96 so im assuming it wont for 94-96, but will for a 97 [img]/ubbthreads/images/graemlins/shrug.gif[/img]. thanks
dan
-Dan
1996 F-250 PSD, 195k, 4x4, Supercab, LB, 3.55's, 4" lift, Built Auto with Precision converter, 150cc injectors, Autometer Z-series Pyro/Boost/Tranny/Diff guages, DIY open element intake, Sandpiper Diesel Performance 4" exhaust, TS 6pos. chip with 2L Motorsports tunes, Shimmed FPR, Modded IDM, Stainless HPX mod from ITPDIESEL.com , Baldwin Coolant Filter from Dieselsite.com , Bilstein shocks on all 4 corners, 315/75 BFG A/T's on 16x10 black Rockcrawlers, Custom front bumper, Ranch hand rear bumper, Warn manual hubs, Sparky's AIC, Full chrome grille, 318hp 643tq #24 sitting in the garage: 6.0 Intercooler
My Webshots
[URL="http://www.thedieselstop.com/forums/
It should work. I thought the only change to the connectors was the contact coatings (zinc - early, gold - late). There was a current thread going on this, but I don't recall whether anyone is using it. Cheers!
are these cheaper??? hold up better??? why I guess is what I am getting at. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me. '86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
Is that a reference to the High Performance CPS from International thread???
I have not read it yet, once it hit 6 pages I said screw it I am not even gunna try.
Diesel Rod
OH NO!..........the rediculous CPS thread has invaded the dungeon now too [img]/ubbthreads/images/graemlins/tongue.gif[/img] lol.
If you want to change your timing, just do it with the program, don't jack it up in the program just to remove it with a cps lol.
I'm sure it will work but why?
Charlie
well honestly i was just curious. with what i have read in the super duty forum (which wasnt all of it bc its over 20 pages now) is that the 466 cps helped increase mileage and made the engine run quieter/smoother (which would obviously happen with less timing). i figure it may be worth trying out, so why not? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
-Dan
My Webshots
Well, I could see how not having a chip that you can play with the timing on might make you want to go plop down over 100dollars for a cps to replace one that is working fine in your truck, but if you don't have a chip, and you're running stock PCM timing tables, then retarding your timing isn't going to help you anywhere except smoothness. I don't see how milage could increase with less timing than stock. For those running a chip with really advanced timing, I could easily see how retarding it a little could help out in many ways, but then again, if you have a chip, why not just change the timing yourself and keep the 100+dollars in the bank?
If you have a chip, change it yourself and keep your money, and if you don't have a chip, retarding your timing is not what you need.
i personally have no way of programming my chip. a lot of people like to keep a spare cps in their truck so i figured with hearing good things about this cps why not give it a try, and hey if i dont really like it, i got a spare. [img]/ubbthreads/images/graemlins/cool.gif[/img]
-Dan
My Webshots
Just a thought, but couldn't you just slot the hold down bracket bolt hole and adjust it like that? Timing is playing with matches though. I don't think stock or even slightly modded would run right with too much timing, but with a little more than stock I would say you could toast something. Too much timing makes lotsa heat in places you don't want it. Maybe someone with more knowledge on the subject will chime in.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
Guys, I've been following the "Blue CPS" thread in the SD forum and it seems like they might be on to something. So far, a lot of guys have tried it and most, if not all, report some benefits after putting a few miles on it. I put one in my '96 PSD about 550 miles ago and, I must admit, it does seem to be quieter and smoother. The power seems improved too.
I know all that seat-of-the-pants analysis is suspect at best and many people are suseptible to the placebo effect, but I have kept a log of fuel mileage for the last couple of years and continue to do so. We'll see how the DT466 CPS affects mileage in the next few tankfuls.
The latest theory on why this works is that the T444E commonly has too large of an airgap that the CPS has to read across. The DT466 CPS has a noticeably stronger magnet and is able to read across the gap more consistently resulting in a smoother running engine.
As for me, I'll be putting one in my wife's '02 soon and using the one I take out as a spare after putting on a new o-ring.
MINE: '02 F250 4x4 CC SWB 7.3L PSD, 130k, 4" downpipe and straight exhaust, open-element Amsoil Eaa, Baldwin by-pass filter, 48 gal aux. tank, SCMT 1705 (Tow Safe Level)
WIFE'S NEW: '06 Dodge Ram 2500 SLT Quad 4x4, Cummins 5.9L
[color:"red"] FIGHTIN' TEXAS AGGIE CLASS OF '92 [/color]
If the only benefit is a timing change, a chip would be a better way to go. However if the DT466 CPS provides a stronger more reliable signal, then that would be a reasonable reason to switch. I have over 80k on my current CPS, I may just pick up the 1807339C92 at IH and try it. Whichever I end up running, I'll have a spare.
Just checked Kurtt IH, $105 for the DT466 CPS, $12 less than the stock one there...
