Dual Mass Flywheel? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 12-09-2008, 12:28 AM   #1 (permalink)
Dual Mass Flywheel?
Hey guys, I'm would like to know what the difference is between a Dual Mass Flywheel and a solid one. Which is better? I'm going to do a standard swap in my 99psd from automatic, so I currently have nothing for a clutch kit. I plan to buy the mid level kit from South Bend for a ZF5 psd.
99.5 f-250 supercab long bed psd ZF5 swap 4x4 viper blue leveling kit ts 6 position chip banks bighead diy intake 6" stacks zex nitrous
Sinful Rides is offline
Old 12-09-2008, 01:19 AM   #2 (permalink)
chris u's Avatar
Sorry I don't have any info but will be keeping an eye on what you get as I will be replacing my clutch.
97 F 250 4 inch lift with toyo LT 285/75/16 tires on ultra 16/ 10 wheels. Five speed manual transmission. Edge evolution programmer set on level 2 race. MBRP 4 inch turboback exhaust DYI 6637 intake and s&b cold air intake still trying to
decide what to use, ISSPRO pillar mounted gauges and a nice stereo system not going to list all that.
2007 chevy cobalt K&N cold air intake,Eibach prokit springs and 205 50 ZR 17 BFG g force sport tires on Konig wheels. With a sound system that will make you deaf.
2004 polaris sportsman 700 twin EFI with ITP 589 tires.
2001 honda cr 500 last year of the big 2 stroke.
98 polaris rmk 700 with big bore and way to much to list.
97 rmk trail 500 a little clutch work.
2005 ford focus ZX4 wifes car. Totaled 10/08
07 Mazda 6 wifes new car.
2000 F150 5.4 auto wifes truck
chris u is offline
Old 12-09-2008, 02:31 AM   #3 (permalink)
PSDfreak's Avatar
The dual mass flywheel in basic terms is composed of two plates with dampener springs between the two plates. The springs absorb vibration/noise, however, over time they wear out and the two plates develop excessive movement between each other, which in extreme cases has been seen to even crack the tranny case.
The single mass is exactly that, a SINGLE flywheel. It will have some vibration/noise off the, but over time you learn how to drive to truck in such a way to minimize it. Its really not that bad and a much stronger setup that a the dual mass unit.
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
Old 12-09-2008, 09:45 PM   #4 (permalink)
Justin C.'s Avatar
If I remember right when you buy a South Bend clutch it will come with a single mass flywheel. MUCH better than the dual, much easier pedal to mash. Only disadvantage is that they are quite a bit noisier than the dual mass. You will hear a lot of grinding at low RPMS. It's normal and won't hurt anything, and you get used to it. Another thing, I bought the Con OFE for my truck, I think it was $900. The dual mass flywheel alone will cost you $1,000+ from Ford.
Justin
Justin
1997 F-250 Power Stroke
- 230k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, BDP live tuned
2005 F-350 Power Stroke (work truck) - 220k
ARP Studs, PHP 40 hp flash
Justin C. is offline
Old 12-09-2008, 10:30 PM   #5 (permalink)
I installed a solid flywheel in mine when the dual mass started coming apart on me, I did not notice hardly any change in noise levels between the two. Basically the dual mass is a piece of junk and just one more thing to go wrong in your truck. Put in a solid flywheel and be done with it...
Dave
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
Old 12-10-2008, 12:25 AM   #6 (permalink)
m_beeson's Avatar
I guess that question has been answered...
could you guys be so gracious as to recommend a company, and a product? thanks.
1997 F250 HEAVY DUTY 7.3 L
* Tymar intake, 3" Down Pipe, 4" Exhaust (no kitty)* Post mount gauges * BD cool down timer * FPR shim * IDM mod * 4R100 trans * ITP Diesel HPX Line * Banks 1.00 (refurb) * DP Tuner *
m_beeson is offline
Old 12-10-2008, 05:10 AM   #7 (permalink)
I had a Luk kit put in my 1994 and I agree with "You will hear a lot of grinding at low RPMS." I push in the pedal sooner while decelerating. Pedal effort is much higher but somehow the clutch feels more solid on takeup. Shop around - I found enormous variation in price here in Canada
1993 F-350 crew cab 4X4 gas/propane engine C6
1992 E-350 15 passenger IDI 7.3 diesel, E4OD
1994 F-350 crew cab 4X4 Powerstroke 5 speed
2000 F-350 crew cab 4X4 Powerstroke 6 speed
2002 F-350 crew cab 4X4 Powerstroke 4R100
1999 International 4900 DT466
1995 Suburban gas 5.7 auto
nattres is offline
Old 12-10-2008, 04:08 PM   #8 (permalink)
I installed the Luk clutch and solid f/w. I went to the "allaboutclutches" store on ebay, printed off the add and took it to Auto Zone. They did a price match and even though they included the shipping costs from the online store, I still saved about $150-200 on both parts from them. Food for thought.
James
brownforddiesel2 is offline
Old 12-10-2008, 06:56 PM   #9 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
I went with the SouthBend Con-O for my 1994. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is online now
Old 12-10-2008, 07:33 PM   #10 (permalink)
rednexx's Avatar
My Photos: (20)
I used a LUK clutch and solid flywheel in my IDI motorhome and a Southbend Con OFE in my 99' superduty. The LUK cluthch is quiet, smooth and easy in the ZF-5. The Southbend is noisier, a little grabby and a very light pedal in the ZF-6. I think the grabbiness is due to the organic/ferrous material, but that clutch will hold a lot more hp/torque than the organic anlone sufaces.
The 99' and up superduties never came with a dualmass flywheel, so I don't think one is even available. Either brand you go with, I think you will be happy.
Early 99 F-250 Superduty X/C SB, 6 speed, South Bend Con OFE clutch, 4" turbo back exhaust, Ebpv Brake Mod, DIY Tymar, Hutch Mod, 2" leveling kit, 315/75/16's, DP tuner ( 60tow, 80econo, 120race, 140extreme), Warn premium hubs, Autometer pyro, boost, tranny, and fuel pressure gauges. AE if anyone in the area needs.
76' (updated) E series 24' Motorhome - 94' 7.3IDI w/ATS turbo (Brand spank'in new turbo spec motor ) ZF 5 speed, LUK clutch, Borg Warner 1356 transfercase, dana 60 front, 3.73 gears, 245/75/16, and its a 4x4 too!
My Gallery
http://photos.thedieselstop.com/show...0/ppuser/80710
Next........MORE!!!:
rednexx is offline
Old 12-10-2008, 11:53 PM   #11 (permalink)
Thanks for the info guys. I was leading more towards the south bend with a solid flywheel because I want to add some power down the road, and do a little sled pulling. No major competitions just at the local county fairs, maybe 3 times a year.
Old 12-12-2008, 02:58 PM   #12 (permalink)
jspd234's Avatar
solid 1 piece is the way to go. dual mass falls apart under heavy loads. i switched to the 1 piece and other than a bit of chatter at take off, its a great unit!
06 F350 xlt sport fx4 srw lb cc 6.0 at afe pg7 cai & accufab polished power elbow, zoodad, dieselsite trans filter n coolant filter, fumoto, 4" turbo back exh. readylift 3.5" lift, 17" atx teflon thugs 315/70 firestone destination mt's. jvc cd dvd sirius head unit with 4 infinity kappa speakers 4 channel infinity amp 10" jl console sub 500 watt jl amp microvision dvd & headrest monitors 4 the kiddies in back!
01 chevy monte carlo ex-nascar southwest tour car raced in the american stockcar challenge(2007 champion!!)
02 sanger V210 black scorpion 330hp 2 fat sacks proflight tower 4 infinity 6x9's rf400 watt amp 12w7 jl sub rf 1001bd clarion amfmcdsirius head unit 4 clarion marine speakers 5 ch hifonics amp 10" bazooka sub encl firing a jl 10w3
09 crf450x
06 drz110 4 tha kid
08 crf150f 4 tha wifey
07 intl 4300 dt466 allison century 612 wrecker alcoa's
04 ford F650 xlt supercab 4dr cat C7 allison century 21 ft carrier alcoa's
97 ford F450 xlt sd 7.3 5 spd century 412 wrecker
jspd234 is offline
Old 11-04-2010, 10:00 PM   #13 (permalink)
I would go for the solid one. I heard many stuffs about the dual mass that it is a failure. It is usually replaced when the clutch needs changing.
Flywheel
brandon mitchel is offline
Old 11-04-2010, 10:18 PM   #14 (permalink)
I had a 95 F250 with the dual mass and when it started to go bad it would make the engine run like it was going to stall when ever I would start it or shove in the clutch at a stop sign. I didn't realise what was going on until my starter hung up. I went with the luk. No more problems. Mine was bad from the start. Ford kept replacing injectors under warranty even though they didn't have any codes.
JERRY H is offline
