I recently installed my new 3" downpipe and I think I may have made a couple of the cuts too deep around the firewall weld seam area and now I get an awful lot of engine noise from that area.
Would putting down some Dynamat material or something simaliar in the floorboard firewall weld seam are help to reduce the cab noise, or should I try something else?
97 F-250 XLT, Super Duty, PSD, Super Cab, 4x4, Long Bed, Wildman Tow Chip, Tymar Intake and 3" Downpipe, Autometer C2 Boost, Tranny, and EGT gages, towing my 20' + 5' Goose Neck Deckover trailer.
Yeah,I Don't suggest dynamat unless you got deep pockets.. of course your not going for a full install so it won't be much... I have similar issues but i didnt make enough space for my downpipe, so it rubs, After doing my insolite and raammat from RAAMaudio - Quality and Value in Automotive Sound Deadening
it helped alot, I still have to make more room for the downpipe, but roadnoise, and of course the sound in the truck is alot better aswell.. Closed windows cruising at 70 with 4.10s I can have a conversation with passengers using my "inside" voice haha
goodluck!
aloha
-patch
__________________ 1996 F250 X-cab SB, zf-5, open element intake, tymar 3-4" DP, 4inch dual DE exhuast,gutted EBPV,MidWest Shortshift kit, DP-tuner chip,Gauges,
sounds, with a bunch of rammat and ensolite in the cab.
1997 f250 longbed xcab,zf-5, 4inch lift with 18 inch wheels and mickey thompsons
Motor all stock for now..
1994 f250 with a custom dump/flatbed heavy duty winch up front, 7.3 idi, None turbo...
If your cuts resulted in even small open holes through the firewall at the seam, some high temperature caulk can help that out as well. Just seal it up, from either outside or inside.
Some have also recommended tar based roof underlayment that has the aluminum surface on one side as a less expensive sound deadener than DynaMat. Does not work as well (or so I hear) but costs a LOT less. Pull up carpet & pad and install on metal floor aluminum side up, reinstall carpet.
__________________ THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
