Old 08-19-2007, 11:56 PM   #1 (permalink)
dynoed today, a couple questions
So I went and dynoed today OD off i got 362hp/650tq OD on i got 349hp/723 tq. Those are corrected numbers only about 3-5% added since the weather was about perfect for dynoing. Im pretty happy, but at the same time a little dissapointed, b4 the hpop, idm and tranny mods I was at 340hp/625tq OD off so the idm and hpop only got me 20h and 20t roughly.
Id like to hit 400rwhp with stage 1s. So heres my questions, I believe Beans stage 1s use stock nozzles (?) if so is this a possible goal?
What would add more power dual hpops or Beans D66.
Is there a way to use dual hpops without doing a full blown elect. fuel system?
Dan
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 08-20-2007, 01:05 AM   #2 (permalink)
Re: dynoed today, a couple questions
I'm not sure on the first few questions, but I know the BTS HPOP setup does not require a electric fuel system. On the OBS trucks they add a SD front oil reservoir and SD fuel filter housing in place of the stock setup.
There was someone, I don't remember who, that did the Swamps Gen3 HPO and removed the passenger side fuel bowl bolt to allow it to move just enough to clear the pump. I think the mount was 1/2" off when all was said & done.
'96 F250 XLT, PSD, 4x4, ExtCab, LB, Auto, 3.55.
11-06: DIY Open Element, EBPV & TC exhaust brake.
02-07: 40 gal '05 F550 aft-axle tank = ~60 gal total.
03-07:DIY/RDS stage 1's, 220,356mi, BTS downpipe & 6pos chip.
04-07: 226,000mi 277HP, 543TQ, Graph
05-07: EGT, Boost, Trans from Tymar
06-07: 4" exhaust, 31 row 6.0L trans cooler
08-07: BTS Transmission.
09-07: 80.76 @ 16.527
My picture & diagrams
danjreed is offline
Old 08-20-2007, 01:40 AM   #3 (permalink)
Tom S's Avatar
My Photos: (20)
Those look like excellent numbers for those injectors. Are you sure the correction factor was that low? If you can post up your sheet that would be great. I do not believe that the SD fuel bowl is compatible with the stock mechanical pump. You can use a SD fuel bowl but you will need a SD electric fuel pump or equivalent to go with it. Whose programming are you using that looks like it is doing nicely.
Tom
Tom S is offline
Old 08-20-2007, 02:41 AM   #4 (permalink)
My Photos: (15)
what is the change in torque from D to OD from? I realize there is a gear ratio difference changing the toque to the wheels, but I though the dyno would compensate for the ratio differences???
Sorry for the newb question. I've only heard of people running dynos in direct drive.
wbones9 is offline
Old 08-20-2007, 11:20 AM   #5 (permalink)
I've never dyno'd, but I would guess it's because of lower rpm in OD.
'96 F250 S/C 4x4 4.10 auto, Tymar intake, 3-4" DP 4" exhaust, Edge Evolution, Hypermax IC, Autometer gauges, Hayden 679 trans cooler, Airlift bags w/compressor and in-cab controller, built trans from KTS, Rancho 9000's, 19.5" rims and tires.
'97 F350 C/C 4x4, 3.55 auto.....just starting to mod
Lance 921 camper, 9.5' w/slide-out
'88 Jeep Cherokee, 4dr pick-up conversion rock crawler, D44/D60, Warns, CTM's, 37's, etc.
rocknxj is offline
Old 08-20-2007, 11:30 AM   #6 (permalink)
BIGRED95's Avatar
It was good to see you at the dyno event Dan, I'd say your at about as much h.p. as you are going to get with those injectors. You'll probably have to step up to some II's to get 400+. Steve did 427 with the same mods as you but with Beans II's.
Justin
98 12V QC, 282,000 +, 5 Speed, with a few power enhancements
SOLD
2000 F-350 XLT CC SRW CC PSD, 249,000+Miles, 6 Speed trans with Luk Con-O-FE clutch, 4" ATS Straight piped, Tymar style intake, Ready to start modding.
Meridian Motorsports Dyno Jet 5/13/2006
219 HP 457 TQ
SOLD:
Lifted 95 F-350 XLT Crew Cab Srw Lwb Psd, 268,000 + miles, 35*12.50*16.5 Trail Cutter Radial RT,4.10's, BABY SWAMPS, Humped HPOP, Homeade Tymar setup with custom 4" intake, Gutted EBPV, Modified turbo pedistal, 1.0 turbine housing, CTI AIC, Auto Meter Lunar gauges, BDP 5 position chip, Complete Alpine sound system, Automatic, Billet torque converter, Tru Cool 28,000 lb external trans cooler, Bully Dog down pipe, 5" twin turnout stacks, 6.0 intercooler with custom built pipes, Optima red top batteries, Wanting more mods!!!
My webshots homepage
Bully Dog Dog Days Of Summer Dyno Pull 7/9/2005
347 hp 660 torque
BIGRED95 is offline
Old 08-20-2007, 07:45 PM   #7 (permalink)
Hey guys thanks for the comments, Tom Im still working on getting over to my friends house to use his scanner once thats up Ill post dyno sheets, and try to detail the mods the best I remember, Im getting old + diesel fumes [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. I guess they have a little weather station programmed in the dyno program they tested this by running trucks early in the day at about 5% correction and then in the afternoon at about 15% correction, result numbers were within about a nats @ss, the morning I went was perfect the dyno op said, not too cold not too hot, humidity was a up just a little for here (in the desert), he got to rambling a little about it, kind of over my head but it seemed to make sense.
The only thing I know about D and OD on the dyno is that in OD off I can go up to 75 mph which on the road I would never do, and OD on I was going about 100mph or better which Ive been known to do [img]/ubbthreads/images/graemlins/wink.gif[/img] that being said I dunno why but the torque numbers were substantially (thats spelled wrong I think) higher and hp was a little lower in OD on.
Hey Justin it was good seein you too(even though your with the DOD** darkside [img]/ubbthreads/images/graemlins/biggrin.gif[/img]), I wish Id got there sooner to see you run, that Holset is big. Sunday a RX7 with a big (I mean big) garret came in and did like 375 hp, it was cool and emabarassing at the same time, oh well his tq was low and I could run over him effortlessly [img]/ubbthreads/images/graemlins/smirk.gif[/img]
So turbo or hpops?
As far as the programming Beans! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Big_Dan97's Photos
