06-03-2008, 04:54 PM
#1 (permalink )
Early 99 spider question
When installing my early 99 spider in my 97 do I use the o-ring for the early 99 or the 97 or are they the same?
Thanks!
Tgorsuch
1997 PSD 4x4 F250 Crew Cab, Red, Auto, DP, NAPA 6637 Air Cleaner, Autometer Gauges on Pillar, 3.73 gears, 240,000 miles, 16 to 19 MPG, 10 MPG towing 30' fifth wheel and 20' Bass Boat, TW 4 position chip, Fuel Heater Mod.
Full force Stage I's. Modified turbo ped, Gutted EBPV, 6.0 IC, 6.0 trans cooler, CCV Mod., BTS Trans. 07 front & rear axle w/coil springs, Blistein shocks, Fox Steering stablizer, Front 4 link, superduty grab handles.
http://terryssite.typepad.com
06-03-2008, 05:17 PM
#2 (permalink )
Been a while since I did mine. You mean between the turbo outlet and spider? Pretty sure I used my stock one.
06-03-2008, 07:10 PM
#3 (permalink )
Originally Posted by
tgorsuch
Thanks!
Tgorsuch
I used my original one because thats all I had, I believe they are the same. You do have to use the early 99 clamp. Good luck
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
06-03-2008, 07:53 PM
#4 (permalink )
DIESELDUTTON
Frank
Franks is right, the gasket is the same for the obs and the early 99........
Jim
529/1220
10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
#3
06-03-2008, 08:59 PM
#5 (permalink )
Ok, thanks a lot. It looks like I need to get the early 99 clamp and I will be set.
Tgorsuch
06-04-2008, 09:14 AM
#6 (permalink )
Does anyone have the part # for the early 99 clamp?
Tgorsuch
Linear Mode
» Site Navigation
» Other Sites
» Buyers Guide
» Network Links
