Old 06-21-2008, 09:21 AM   #1 (permalink)
tgorsuch's Avatar
Early 99 Spider to Turbo Question
I am in the process of finishing by 6.0 IC upgrade. Does anyone know the part number for the clamp to connect the early 99 spider to the stock 97 turbo?
Also, on an earlier thread I was told to connect the boost gauge and the map sensor to the hot side of the spider for best results. Should these be separate connections or can I use a T?
Your thoughts are always appreciated.
Tgorsuch
1997 PSD 4x4 F250 Crew Cab, Red, Auto w/Trans Cooler, DP, NAPA 6637 Air Cleaner, Cat Deleted, Autometer Gauges on Pillar, 3.55 gears, 195,000 miles, 16 to 19 MPG, 10 MPG towing 30' fifth wheel and 20' Bass Boat, Wildman 4 position chip, Fuel Heater Mod.
Full force Stage I's. Modified turbo ped, Gutted EBPV, 6.0 IC., CCV Mod.
http://terryssite.typepad.com
tgorsuch is offline
Old 06-21-2008, 11:39 AM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
Here's the part number for the clamp:
Turbo Compressor Outlet to Y-Pipe Clamp (used for 99+ Intercooler Retrofits)
(Ford) F81Z-8287-DA
You should also be able to use a tee for the connections. Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
