ebpv exhaust brake ? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 06-17-2007, 09:09 PM   #1 (permalink)
My Photos: (6)
dose any one have the wire schmatic for the switch? i fallowed baz's instruction on his site. but the link to the schmatic for the switch dosent work, i searched the achive and forums all day yester i cant find it, any help is appreciated. thanks
97 F250 EXT CAB LWB. 4X4, HEAVY DUTY REBULIT AUTO(DONT LET BRAKES PLUS DO A TRANS FLUSH THEY SEEM TO HAVE TROUBLE GETTIN ALL THE OIL BACK IN THE TRANNY). BANKS DOWNPIPE,HOMEMADE TYMAR INTAKE, 18 K MOD.
87 F250 EXT CAB LWB 4X4 WAS AUTO NOW A 4 SPEED, STRAIGHT PIPED, REDNECK AIR INTAKE
86 F350 CC LONG SRW 4 SPEED, OWNED FOR TWO MONTHS THEN IT BURNED.
2000 F350 CC LONG SRW 6 SPEED ,STACKS AND AIR HORNS. 6.0 AIR FILTER, STRAIGHT 4 EXH TO THE 5IN STACKS- R.I.P. (WRAPED IT AROUND A POLE 80MPH)
PARTY LIKE A ROCKSTAR.....GO BIG OR GO HOME!
squirl919 is offline
Old 06-17-2007, 11:00 PM   #2 (permalink)
DIESELDUTTON's Avatar
Re: ebpv exhaust brake ?
I'm pretty sure Swamps diesel has it on there website. I use the SP diesel ssebtc exhaust brake module it was around $250.00 and you can change your lock up and unlock points it works great. The instructions for wiring it up in a obs are kinda tough but once you locate the wires its a piece of cake, just a thought. Good Luck
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
