Old 04-29-2006, 10:54 AM   #1 (permalink)
Edge evo and tranny shifting
I just picked up an edge evo and had the tranny redone last week. Now i seem to get a funny 2-3 shift in all the programs, almost like its confused i guess would be the best way to put it. Is this just how its gonna be with the edge, or do i have other problems? Also whats the average tranny temp for the e4od? Thanks.
96 f-250 4x4,ext. cab long box,4.10ls,auto,shimmed fpr,tymar intake,4"exhaust w/5" mitre cut stacks,DP tuner F5, 4" lift and stage 1's.
green600zr is offline
Old 04-29-2006, 01:23 PM   #2 (permalink)
Re: Edge evo and tranny shifting
the edje evo does raise the line pressure in the trans. it made mine shift a little harder. the temps should be about 80 degrees above the out side temp to the best of my knowlege.
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
<span style="color: #CC0000"> #26</span>
krowell is offline
Old 05-05-2006, 05:44 PM   #3 (permalink)
If you don't like the way the tranny shifts with the EVO just call them up and get a return authorization and send it to them for removal of the tranny shift enhancement part of the programming. They do it for free and turn around time is pretty fast. Before you send it back you'll have to reprogram your truck back to stock.
Larry [img]/ubbthreads/images/graemlins/cool.gif[/img]
02 F250XLT SD CC LB 4X4, Silver, SD Air Lifts, 4R100, Westin Sportsman grill/brushguard, Leer Shell, AIS Severe Duty w/added fender intake, Edge EVO running 80 HP, ISSPRO's w/cubby mount, Rancho 9000X's, Banks 3 1/2" downpipe, BTM, 3 1/2" exhaust front to rear with 5" stainless tip. Sonnex and Tricum's. Fumoto Valve. Royal Purple ATF. Tru-Cool 4590. Tekonisha Prodigy. SP Diesel SSEBTC Exhaust Brake. Like new 88 Vacationeer 11.4' or 2008 Cardinal 31SB, 1992 Bayliner Trophy and the itch to go, baited hooks and the need to fish, loaded guns and the need to hunt.
Larry P is offline
Old 05-07-2006, 05:32 PM   #4 (permalink)
my trans has allways had the "confused" way of shifting into second-third when i got it,it was bone stock 160K on it and dont know if the trans ever had work on it.
when i got the evo and programed it into my truck,i did notice better harder shifts,but with in a week the truck now slams VERY hard into thrid gear unless i let of the peddle a bit.
as for the temps,i live in FL. and a hot 93 degree day if i just drive slowly the temp for the trany will get to 190 some days,at night it stays around 160-170,and when i blast it hard,day or night i have seen it go 215
Press. gets to 28 i think?i have not driven the thing in over a week so...
1996 F-350 7.3 XLT 2 door SC 2WD DRW's 410gears, E4OD slush box, 188K --- 5" air filter, 3" into 4" turbo back wide open,gutted EBPV,shimed FPR, DP Tuner F5-switch 80hp econo tune & lope idle tune ---
1994 Yamaha FZR 600cc ---Yoshimura strait pipe, stage 3 jets---
BlackSmoke96 is offline
Old 05-15-2006, 07:18 AM   #5 (permalink)
If you are running the stock cooler those temps would be about normal. When I had my 97 I had to install the biggest auxiliary cooler on the market to keep my temps down below 220* when towing my 32' trailer. After the cooler install I never saw above 195* on the hottest of days. I towed the trailer with the truck stock for 2 years before I installed the aux cooler and guages so how hot the tranny got during those years still gives me the creeps considering the stock cooler wouldn't keep cool an auto tranny on a Honda Civic.
Larry P is offline
