EGT & tranny gauge probe locations. - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 04-03-2008, 10:25 PM   #1 (permalink)
mattski's Avatar
Just received my A-pillar triple gauge mount and gauges!! Just wondering what the general consensus is on the best location for the tranny temp probe. I'm assuming it has to go into the pan but is there a "better than others" location for it? Also same question goes for the EGT probe, I would like to go pre-turbo but there isn't really alot of room in there. Any suggestions would be great.Thanks.
Mattski
97 F350XLT, CC, SRW ,LB 4x4, 4.10LS, E40D rebuilt with triple disk billet TC & superior shift kit w/sonnax valve, genuine Tymar intake, Diamond Eye 3" DP- 4" back to 5"tip, Stage 1 inj, IDM mod, gutted EBPV, modded pedestal, TW 6 pos chip, 1.0 turbo, 7.3 I/C, shimmed FPR, Dieselsite 203' stat, Tymar HX, 2 Tru cool tranny coolers, 3"RSK w/X-codes, 5" Icon's, Bilsteins, 315/70R17 Mickey Thompson MTZ's on 17X9 Pro Comps, N-fab steps, Fuel filler mod, Dipricol Optix pyro, boost & tranny temp on A-pillar, Pioneer CD, SIRIUS Sat.
mattski is offline
Old 04-03-2008, 10:50 PM   #2 (permalink)
ZnJsdad's Avatar
I put my trans temp right into the test port on the drivers side of the transmission, really simple no drilling or tapping. As for the EGT I pulled the passenger side inner fender and drilled & tapped the exhaust manifold right where it bends to the up pipe. Gotta love those "A" pillar gauges
If I can find the links I saved with the pictures from different posts I will post another message with it.
97' F350 Crew Cab 4x4, 150k, Tymar Intake & 4" Turbo Back Exhaust, Z series gauges (A-pillar), Tru Cool Trans cooler, TW Chip (6-position & just getting started)
ZnJsdad is offline
Old 04-03-2008, 10:52 PM   #3 (permalink)
ZnJsdad's Avatar
Should have looked real quick before I put the other post up. Here is the link I used to install my gauges.
Gauge Installation - 1994-1997 Power Stroke FAQ
Good Luck!!!!!
ZnJsdad is offline
