The fans are made by Flex-a-lite,I got 'em from Summit.Yea,they work fine,no probs.I don't do any heavy towing but work it pretty hard in the sand a few times a year,so far so good.
Brian
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,open intake,SD IC,1.0 Housing,Pedestal Mod,Gutted EBPV,dp,5"no muff, Baumann TCS controlled e4od,"I LOVE that thing"!,Baumann VB kit,UCC Custom Billet T/C-VERY low stall speed,Mag-Hytec pan,dual True-Cools,remote filter,3 pos.T/C lock-up switch w/LED,Elec.fans on trans.& engine w/Derale adj.stats,Gauges,Kingpin D60 w/Lock Right,Detroit Locker in the 10.25,4.88s,4" Nat. springs w/ORU-SRK in fr.,crossover steering,10" Atlas springs in rear-no blocks!,Bilstein 5100s,38" PJ Dirt Grips on 16x12" M/T Classic Locks w/Centramatic balancers,Warn hubs,Powerslot rotors,Hawk pads,Can-Back canvas top.
About how much am i lookin at spending? And does flex a lite make them for the fords. I've seen a lot of them for the GMC's. Which i'm thinking the dual fan setup for the D-max's (I've seen them for around 200 i don't know if thats a good price or not) Would work.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
I dug up some more info: 13.5 in.dia,4600 cfm,$299.00 from summit.Not the cheapest option out there for sure.The ones that I got are universal I just had to make up the mounts.I'm using a Derale adj. stat that cost about 30 bucks and works great.Got the same stat on my trans fan.
Brian
after havign a dual setup for a year, two 16", with one contoller. I would change it up a bit now, one 16" and one 14" with teh 14" on the pass side with the tranny cooler. Then have one contoller that puts both on with the rad temp, and a second that puts JUST teh 14" with teh air and manually for slow hard 4x4ing to cool the tranny.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
I'm still just running one single fan out of an older Honda, crude, but it works.
Taurus or Windstar dual fans fit nicely as well, mid to late '90's if you want to get some from a salvage yard.
Last I checked the '95 Windstar fans were available on ebay new for about $120
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
The best set up is to use a relay. You can run off the battery through a fuse or circuit breaker, then to the relay & to the fan.
Use a manual switch in the cab and / or a thermal switch under hood to power the relay and turn the fan/s on. There are temp controlled switch kits on ebay, as well as thermostatically adjustable units from folks like Hayden. You can spend a lot of money to make this happen, or you can do it on the cheap with some time.
Does it really take 200A to run a fan? I have a circuitbreaker that I was planning on throwing on. I was thinking power from battery to circuitbreaker breaker to a fuse panel and then run the individual items from the fuse panel... What do you think?
Sam
96 CC F350 SRW - 3" DP - 4-5" exhaust single stack - DIY K&N Intake - coolant filter - secondary fuel filter - rear airbags - Rancho 9's in rear and 5's in front - Pac Brake - 17k Tranny cooler w/ fan - Aux Engine Fan - 1000lb lift gate - jumper cables - Oil temp/coolant temp/boost/pyro gauges - turbo timer - 120 IDM
Soon to be installed Tranny gauge, air horn, Steering Stabilizer, IC, E-350 battery tray/relocate
my two 16"'s run off one 30 amp relay, just the small ones, but I'll split that load soon. I used an open spot in the fuse box and added the wire for it. There are a few open spots to use.
On my '93 I tried two 16" fans I bought from rodpartsdealer on e-bay. Do NOT buy these cheap fans like I did. Get the Flexilites (or other proven, name brand fans) like someone else suggested. One of the fans I got from rodpartsdealer burnt up the first day due to "made in China" poor internal wiring and the brushes/leads shorting out. The other is still working, but only because I took it apart and rebuilt/re-insulated the brush wiring/mountings. Rodpartsdealer wouldn't even answer me and I got stuck with a $55 hunk-of-junk burnt up fan. Caveat emptor.
I used the $51 Hayden adjustable thermostatic electric fan controller, with the screw-in sensor and a/c override, that I got from O'Reilly's. It is part number 3651 and you can see it at this <font color="blue">web page</font>.
There is another <font color="red">BAD ASS</font> electric fan controller at this company: <font color="blue">web page</font> They also have fans with built in integral controllers.
The first thing I noticed was that my stock alternator did not put out enough juice to run these two huge fans (and a/c, radio, ect...) and charge my battery. I measured the current and each fan drew 19 amps. Even after fixing the one fan, it still drew 19 amps. So that is something to consider.
Next, while out looking at alternator rewinding shops, I noticed that they didn't cool my truck very well. I now know that this was because I didn't have them properly shrouded around/to my radiator. It is very important that your shrouding completely seals the fans to the radiator so that they only draw air thru the radiator.
I never could find what I thought was a reasonably priced alternator and due to the lack of cooling (and one fan burning up while I was out alternator shopping) I went back to my engine driven fan and made the remaining fan as a blower to push air over my a/c condenser. It is still working now 3-4 years later.
I still have the fan controller in a box in my garage. Been there for years, and if your interested in it, PM me.
These are just my experiences and I hope they help you out in your quest.
Mark
1997 F-350, 4x4, CC, LB, BTS E4OD, 3.55 Gears. Bean's Stage II 160cc Injectors With Custom EDM'ed Nozzels. Tony Wildman 6 Position Chip. Dieselsite H2E; 203° Thermostat; Tru-Cool Max LPD-47391, V-10 Trans Cooler. DIY Fuel System - 10 Micron Pre, Bosch 984 Pump, 2 Micron Post, Aeromotive Regulator, pressure safety switch. Tymar Intake. Full Boar 4" Open Exhaust w/3" Down Pipe. Warn Premium Hubs. Autometer Pro-Comp II Trans Temp and Pyro, Banks Boost Gauge. HPO Crossover Mod. Dual Tensioner Installed. CCV Mod.
