I was thinking about putting the super duty fuel pump on my truck. i was wondering how most people set it up and if it worth it ? thanks for the info
96 250 4x4 ex-cab auto with 3.55s so far 6 pos TS chip, homemade intake, 3 inch down pipe , warm up valve engine brake, gauges boost, pyro, trans temp,
engine temp and oil pressure , Sonnax valve/Tricumulato springs
I have a sd pump on my daily driver for 21k now. I have a line coming out of the factory selector, that runs into a water seperator pre filter. it then goes to the sd pump then a fuel filter. Then back into the factory line up to the engine. The factory fuel bowl is removed i have a t off the feed line on the engine to the back of both heads. The factory return lines (that went from the front of the heads to the factory regulator) now goes into an aeromotive regulator mounted to the back of the oil resivoir. then the return goes back to the factory return on the engine.
This is not a hi po system. I would say it is good to around 425 give or take, but is definatly better then the factory junk
hope this helps a lil
Travis
SWAMP'S Extreme Powerstroke Performance
2L Motorsports
Charter Member of www.FOKISD.ORG
99 F350 ext dually 2crueL (moded somewhat)
86 F250 4x4 - C6 3.55Ls[b]
The Mule 1995 F350 CC - 4x4
95 E350 PSD 190k miles
97 F250 ext lb 160k 4x4
97 FSuperduty Plumbers Truck
93 Ranger (soon to have twinned 4bt) My Webshots
ive got a electric setup on my truck and its much better and im running a dahl150 for a filter and its great.
bean has a really good electric setup also.
if you build the setup yourself i spent about $700 for the SD pump, aeromotive reg, dahl 150, stainless head lines, new fuel pickup parts, and all the other little parts you will need add up fast
97 F250HD 4X4 210K MI
4 LINKED FRONT AND REAR ON AIR
tubbz made about 452 HP with a single SD electric pump. I think that is about maxed out because all three of his chip settings made between 450-452 HP. His fuel system is from BDP. I am sure the system from RSP is a good choice also.
Chris
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
I made my own fuel system. I kinda took a different approach and ended up doing the whole thing from a single bronco tank to the 5/8" stainless pickup tube to the twin ele pumps and then 2ea 1/2" lines, 1 for each head. With this setup at idle I will return 1 1/2 gallons of diesel to the tank per minute while maintaining 70psi of fuel pressure. I haven’t installed my electric fuel pressure gauge in the cab yet so I can't verify what my PSI is a WOT.
I have a few pic’s in my sig.
Good luck.
JIM
I made my own fuel system-- 5/8" stainless pickup tube to the twin ele pumps and then 2ea 1/2" lines, 1 for each head. With this setup at idle I will return 1 1/2 gallons of diesel to the tank per minute while maintaining 70psi--
JIM
Are you sure that is enough? [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
You must have 1/8" nozzles [img]/ubbthreads/images/graemlins/grin.gif[/img]
Or maybe the cold temps make the fuel thicker way up there!!
Travis
I come out of the selector valve into my filters mounted on the left side of the truck (2 micron filtration). Then into my S/D pump. ran new 3/8" high pressure rubber fuel line up into the engine compartment. Y'd off into the front of the heads. Returning from the back of the heads. The engine fuel lines are all 5/16" teflon, for the heat around the Turbo area. I'm running an Aeromotive fuel regulator with 70 psi at idle. I wish I'd done it sooner. Keep us posted on your results. Carl
97 F-350,4wd,cc,long bed,4.10,35's,rebuilt E40D,H2E,3" intakes,Head studs,,pyrometer,boost,trans temp,home made open intake,Joe servo IDM, Inner cooler retro,Baby swamps 170/146, Bills 3 position chip,Updated HPOP, home made oil bypass filter system, A/C mod, updated super duty fuel system, 60 gal/toobox combo.
