What pressure are you guys running on electric pump setups with single shot injecters?????
96 f250 ordered and owned since new, 4.10 gears custom built e40d by jim galatioto of ato transmissions. hypermax intercooler,hypermax stage 2 injectors, hypermax h2e turbo,downpipe,4" exhaust,, terminator pump with 2 new 17 degree pumps dp tuner F5 chip with 6 programs,Beans 3" billet intakes and dual superduty electric fuel pumps, tymar 4" intake system, gear vendor overdrive on transmission, ,new 3/8" transmission lines all the way up and v10 cooler in the bumper and dieselsite transmission filter. cat gone up the tree. Coolant filter added, A/C vent mod done. diamond clear headlamps,park lamps and cornering lamps,remote start & ford alarm. Complete inside cab doors floor and headliner completely DynaMat Extreme lined.Late model 3 pinion posi trac installed. SD Starter. LoJack installed.
'95 F250 _Running on Pump Diesel
'02 Excursion Total Diesel Performance LIVE Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
got it on finally. and im at 74-75psi. dont know how since the regualtor is adj form 30-70psi. and it isnt all the way maxed out. had it at 84psi one time then backed off. gibson
D.T.Gibson
1.830.203.1460
new newer rig: '05 greyish/balckish Ford F-350 XLT Lariat, Crew Cab, 6.0L PowerStroke, Fx4, Leather and all the electric goodies besides a moon roof, auto trans, 3:73's, leveling kit. SCT Looney Tune stacked with Edge Juice with Attitude, and 4" turbo back exhaust. 91K.... blew HPOP and headgaskets. In shop for now. maybe by the 8th ill have her back with new long block! sweet!
newer rig: late '99 Red Ford F-350 PowerStroke, 4x4, CC, 4r100 Auto Trans, 3:73's, Stage Coach Conversion, 4" DP to 5" up to 6" stack, aFe Stage II intake, DP Tuner 4pos chip, dFUSER oil crossover line, 10K mod, AIC controller, '06 18" King Ranch Wheels. 225K.
new rig: CUMMINS POWERED '95 F-350 XLT, crew cab, Blue & white, ZF5-speed, 4x4 with auto locking hubs, 4:10 gears, 283K miles, 3" DP to 5" exhaust, Auto Meter A-pillar 3-gauge pod with EGT, Water temp and oil pressure.
Hmmm, 84? I ahve mine at 65 and with just AA's makes a good difference.
1995 f350 five speed with 293,000 miles. Autometer silver Pro-Comp gauges, AA injectors, custom built regulated return fuel system, a TP38 hybrid turbo home built, a Tony Wildman chip, stock airbox that has been modified, and dual exhaust from the downpipe with 5 in stacks, and a 99 intercooler. Not fast enough. YET
I have got the Billet Intakes on Tom and in the process of trying to run and hook up fuel system. I think i am going to hook up the pressure side with the fittings like Tim did in his pictures with the short fuel tubes that you made for me and use your complete regulated system exactly like you have. Everything underneath is done so hopefully late today or monday. I can crank this up. A very special thanks goes out to Tom for his wonderful pictures and ideas and Help that He has giving me on this project and a big thanks to TimC for his great write up and instuctions for the electric fuel system, I have used several of his ideas. Thanks Guys. I will Post photos when finished
You know I read that too and assumed that was correct. While it probably is correct, I wonder though, if Bean's statement is based on using his full fuel system which runs larger hose and fittings all the way to the heads.
I didn't run large lines to the heads when I installed an electric fuel pump and when I read that several people are running higher fuel pressure (higher than 60 psi) and getting good results, I decided to try. I bumped the presure up to around 65 psi and added the boost reference line to the regulator and there is a very defined improvement in performance!
This all jogged my memory and I think there was some discussion about this a long time ago and one of the comments was that if you have eliminated all restrictions with a custom fuel system, you do not need to run excessive pressure to maintain an adequate fuel supply. So perhaps if you have a less than all-out system, maybe there is still performance to be gained from jacking the fuel pressure up some, even with an electric pump supplying the fuel...
[img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] Does that seem reasonable??? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
I was running in the neighborhood of about 40-50 psi and put the truck on the dyno. Bumped the pressure up to about 80 psi and lost about 10 hp. Then dropped it to 70 and was still down on power. Dropped it back to between 50 and 60 and the power came back. Had a pretty nasty rolling idle and dropped the psi down to around 35-40 psi and it idled as smooth as ever and hooked the boost compensating port up to the regulator so it hits about 60-65psi at WOT and the system works great!
Anyone else notice a rolling idle with jacked up fuel pressure?
I see good performance with 65-70psi on a stock fuel system.
No more than 55-60 with an upgraded system with boost advance. If you have the boost-adjusted regulator, don't forget it's 1:1!
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
I think one of the reasons for the 60 psi reccomendations was that the filter housing are rated at 70 psi. I have been running 64 psi for 2 years now. No problems.
Rick H...
__________________ Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp [color:"RED"] RDRCM#20 [/color]
