Old 02-15-2006, 09:51 PM   #1 (permalink)
My Photos: (14)
electric fuel pump relay problems!!
I was curious as to what kind of relays everyone is using with thier superduty fuel systems. I can not seem to keep a relay in my truck. They last a couple months and then they stick on. They get corroded inside and freeze up. what are you guys using, I have been using the standard 30 amp relays, like used in most automotive applications
Thanks Travis
SWAMP'S Extreme Powerstroke Performance
2L Motorsports
Charter Member of www.FOKISD.ORG
99 F350 ext dually 2crueL (moded somewhat)
86 F250 4x4 - C6 3.55Ls[b]
The Mule 1995 F350 CC - 4x4
95 E350 PSD 190k miles
97 F250 ext lb 160k 4x4
97 FSuperduty Plumbers Truck
93 Ranger (soon to have twinned 4bt)
My Webshots
Moremph is offline
Old 02-15-2006, 10:15 PM   #2 (permalink)
Re: electric fuel pump relay problems!!
thats the same one i use and have never had a problem.
97 f350 cc 4x4, srw ,tde1, 4.10 gears,head studs w/ factory gaskets' bts tranny mobil 1 synthetic diesel site full pull injectors h2 turbo, 02 hpop ,twin tymar intake ,beddins custom fuel system ,custom ladder bars,turbo life saver,dead kitty, ,dp tuner 4 position chip,hypermax innercooler,oil filler extension,,maghytec pan,4inch exaust w/ 4" stacks, aux tranny filter,dual aux tranny coolers, autometer a-pillar 3gauge,295 nitto at's,4inch lift,ranchhand bumpers front&rear
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!!
scottginfla is offline
Old 02-15-2006, 10:23 PM   #3 (permalink)
Banned
i went though 4 before i got a good one,like every 2 to 3 months it was going out,its been 6 months since last mine went out.but thats the same relay i run.i keep one in the tool box just in case
tubzz is offline
Old 02-15-2006, 10:35 PM   #4 (permalink)
im running the same relay that the superdooties run i used that blank relay spot in my under hood fusebox
97 F250HD 4X4 210K MI
4 LINKED FRONT AND REAR ON AIR
00 F350 4X4 CC
RIP CHRIS. 03/09/05
http://community.webshots.com/user/barebackjake
barebackjake is offline
Old 02-15-2006, 10:47 PM   #5 (permalink)
Same one for over a year, almost a year and a half.
Need one? I bought a large qty and got a good price, about 1/8 of retail. If you want one I will gladly send it to you.
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 02-15-2006, 10:58 PM   #6 (permalink)
My Photos: (5)
plain ol' generic relay, haven't had a problem in over a year. of course now I'm going to be stuck tomorrow morning [img]/ubbthreads/images/graemlins/tongue.gif[/img] (although technically I have a spare because of having dual pumps [img]/ubbthreads/images/graemlins/grin.gif[/img] )
any chance your wiring on either side of the relay is a little rough? not getting a good ground or something?
Truck: '97 F250 PSD , ext. cab, shortbed, 5-speed, 4wd, 4.10L
Upgrades: BDP Stage I's, Stealth HPOP, BB Turbo with 1.0 wastegated housing, 6 pos DP Tuner chip, SBC OFE, dual SD fuel pumps, traction bars, US Gear OD, MAP regulator, SP Dongle, downpipe, extra 45 gal fuel tank, EGT-boost-TIP gauges, bilsteins, TYMAR, no cat, 3.5" flowmaster into 4" exhaust, gutted EBPV, XM SKYFi2, cab lights, BFG AT 285/75/16, Autoenginuity, 169k on 5/10/06
Coming soon: 6.0 Intercooler
Dyno'd 298/575, 296/582 before Stealth and Turbo
swh22 is offline
Old 02-16-2006, 03:51 AM   #7 (permalink)
I just picked up a S.D. pump. Now I need to figure out how to do the wireing. Could somebody explain how to wire the pump useing this method?????
Also I am glad to read early that I should carry spare relays. Anything else?????
97 f350 xlt cc 4x4(7620# dry & empty) 2nd MONSTER BOX, 3.55 srw ,265 75 nitto, shackle reversal, ranch hand front & back, winch, BANKS exhaust, BDP STAGE 1 INJECTORS , 2002 HPOP, ford intercooler & BANKS Y pipe, Tony's 3 pos chip, ebpv gutted, PS2K off & for sale, JS IDM , TYMAR HX , DIYS intake, dead cat, ac mod, Dahl 100, stock bypass reg and pump, 94 29' H.R. 5er
http://community.webshots.com/album/527019792kpzDvi
davideoftex is offline
Old 02-16-2006, 10:46 AM   #8 (permalink)
Nit
open teh underhood fuse box teh last place in it has no relay , jsut remove teh fuse box and wire thsi spot up.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 02-16-2006, 07:07 PM   #9 (permalink)
My Photos: (14)
I have a bunch of supposedly good ones at work, we get em from kenworth suppose to be better then the generics. haha. but thanks anyway rick.
swh22 how do you have your duals set up. one to each head, or compounding?
Travis
2L Motorsports
My Webshots
Moremph is offline
Old 02-16-2006, 07:16 PM   #10 (permalink)
My Photos: (21)
Hay Travis, I'm using the standard relays on my twin pump setup 1 relay for each pump. I do notice every now and again one of the relays will stick on and keep the pump/pumps running after I've shut down the truck. I just pop the hood and give it a tap and it stops. It's only done it 2-3 times and hasn’t done it in over a month now.
JIM
His: 1997 F350 PSD, CC, 4X4, 4.10's, 35/12.5/16.5's BFG's
Hers: 1997 F250 PSD, X-Cab, 4x4, 4.10's, 315's
All My Photos
Toys/Blown Head Gasket
Drag Videos
motor/turbo/fuelsystem pics
Traction Bars
Father & Son Time
THE_ALASKAN is offline
Old 02-16-2006, 08:08 PM   #11 (permalink)
My Photos: (5)
I have them in parallel, right now I am only running one pump (the other is unplugged at the relay and capped at the pump outlet) and don't have a problem holding 50psi. I wanted to do it all at once rather than try to add a second pump in a year or two when I really need it. Plus I found two cheap ones on ebay when I was gathering parts.
I have a one-way valve that I am going to install in the second pump, then I can un-cap it and plumb it into the "T" that I have after the two pumps. Then I'll put a switch on my dash to turn on the second pump when I need a little extra juice. Might just get to it this weekend. But probably won't NEED the second pump until I go to Stage II's or bigger.
Let's see if this comes through...
<font color="white">.................................... .......</font>-- pump #1 --
tank -- filter/water separator --<font color="white">....................</font>-- filter -- engine
<font color="white">.................................... .......</font>-- pump #2 --
swh22 is offline
Old 02-16-2006, 09:45 PM   #12 (permalink)
My Photos: (14)
thats cool,
jim your set up the same way?
that is exactly what i have been noticing to with the relays, walk by the truck and here the fuel still running!!
Travis
2L Motorsports
My Webshots
Moremph is offline
Old 02-16-2006, 11:05 PM   #13 (permalink)
My Photos: (21)
No, I have a 5/8" pick up going into a filter housing then splitting into 2ea 1/2" line then into 2 ele pumps then into another filter then 2 lines going up to the motor, 1 for each head.
I have some pic's in my sig.
JIM
All My Photos
Drag Videos
Traction Bars
Father & Son Time
