Old 01-30-2007, 03:07 PM   #1 (permalink)
Electric fuel system differences
Does anyone know what the differences are, if any, between BDP and Swamps electric fuel systems for the OBS trucks? My truck has BDP stage 1 injectors. I know the BDP system is good for stage two's, but I don't know anything about the Swamp kit.
96 F350 reg. cab SRW 4x4, original owner. 5 spd. manual with a South Bend Clutch solid flywheel and Con-O clutch kit, clutch petal mod., Truetrac differentials, front and rear, 4.10 gears. Tymar intake, gutted EBPV, 3" downpipe, 4" exhaust, BDP stage 1 injectors, DIY IDM mod, 4 pos chip, Banks technicooler intercooler, shimmed FPR. 324k miles and still rattling.
96F3504X4 is offline
Old 01-30-2007, 03:32 PM   #2 (permalink)
Re: Electric fuel system differences
i'd be interested in finding that out myself, i just emailed swamp for some more info
---Don't run your fingers over my truck and I won't run my truck over your fingers---
97 Reg Cab Long Bed 5 spd, testing out some diy injectors, tymar, 3-4 DP, Cobalt Gauges, South Bend clutch, my own custom electric fuel system (pics soon), 305/70 ProComp A/T's on 16" MT Classics with Air Lift Bags and B+W Turnover out back...driven daily about to click over 200k...working at international gives me access to some fun goodies
05 Arctic Cat 400
95 Honda 750 Magna
97 Toyota 4runner
04 Kubota BX22 with a front loader, backhoe and mower deck - looks mean cutting grass with all the attachments!
"I'm not driving fast...I'm flying low!"
Wreckingball_psd is offline
Old 02-26-2007, 11:37 PM   #3 (permalink)
anyone know the difference?
My F-250 HD
1997 PSD F-250 HD 2wd ex-cab longbed prerunner. 4.10 LS rear. Edge Evolution. BDP electric fuel system. 3'' downpipe to 4'' out. 0.84 Turbo Housing. HPX mod. Gutted EBPV. Tymar intake. 3rd E4OD. B&M deep transmission pan. 4'' Fabtech lift on 35s. Bedcage toolmounts. Prerunner bumper with skidplate. SS brake lines. Flipped steering stabilizers
thegreg92 is offline
Old 02-27-2007, 12:00 AM   #4 (permalink)
I can't tell you the difference between the two, but I can tell you how good BDP pump is as I just installed one. Truck runs significantly better with the electric pump, smoother idle, better throttle response, and no more leaks in the engine valley, aloha.
1997 CA. F350, 4x4, auto, C.C. 4.10's w/PML cover, Tymar intake, 3" to 4" dp, ccv mod, EBPV delete, gauges, DP Tuner 4 pos. chip, 28k trans cooler, HX crossover, BDP fuel pump, ITP boost reg.
watermanh is offline
Old 02-27-2007, 12:31 AM   #5 (permalink)
watermanh, does the truck seems faster? how long did it take to install? was it difficult? would you say its worth the $1000? i wonder if its a worthwhile mod for just stock injectors or just easier/cheaper to fix the mechanical pump as it breaks/leaks. i am pretty close to pullin the trigger on this mod myself. thanks
My F-250 HD
Old 02-27-2007, 12:58 AM   #6 (permalink)
Tom S's Avatar
My Photos: (20)
My truck runs a bit faster in the quarter with the only change being the fuel system. You might want to give BDP a call on it.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Tymar intake, Cowl Hood, 4" Stainless Magnaflow/Aeroturbine exhaust
14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 02-27-2007, 10:54 AM   #7 (permalink)
Not sure of the difference, but when I originally posted this, Swamps system was $750. It was alot cheaper than the BDP system, that's why I was asking about differences. Now the Swamps setup is $900.
Old 02-27-2007, 11:08 AM   #8 (permalink)
I installed the Bean system on my truck.
The quality of Beans system is excellent and after talking with Beans during the install I am confident that if something were to go wrong BEAN would stand behind his product.
I am not so sure others would be so fast to back up their product.
1997 F350 PSD, SRW, 4x4, 5spd, 4.10's H2E Turbo, SD Injectors, 17* SD HPOP, ATS Propane, Banks Intercooler, LUK SMFW, Chipped, BDP Electric Fuel System, AFE Intake, H2E Downpipe, 4" Stainless Exhaust, Autometer Phantom II Pyrometer & Boost Gauges, Reverse Shackle Kit.
Brad52 is offline
Old 02-27-2007, 11:51 AM   #9 (permalink)
I emailed swamp as mentioned in there somewhere...no response...made my own
05 Arctic Cat 400
95 Honda 750 Magna
97 Toyota 4runner
Old 02-27-2007, 12:38 PM   #10 (permalink)
Thegreg92,
Yes the truck does seem to run faster/better. Installation took 5 days @ 3hrs per day after work. Should have been quicker but I had problems with a fitting that is supplied for the drivers side head. Bean says this fitting is only for 97 models. In the end I used the stock fitting and location for this location. Definitely worth the money. I have a CA model thus changing the fuel pump is a real PITA, thus when my 2nd pump only lasted 35K I decided I was not going to do this again, aloha.
Old 02-27-2007, 01:51 PM   #11 (permalink)
I too am very happy with the support I have gotten from Bean. He showed extreme patience with me when I was telling him that my chip wasn't working. He kept telling me that I didn't have the PCM clean enough, when it looked clean to me. I was sure I had a faulty chip. Sure enough, after a super thorough job, I haven't had a problem since and that's been over a year. I don't know anything about Swamps, it's just that with the kit they offer it initially was quite a bit cheaper than Beans. Now I think I'll just stick with getting Beans setup.
Old 02-27-2007, 08:19 PM   #12 (permalink)
As far as i know beans uses a super duty pump in there system as far as swamps i have never heard anything about it
caterpillartim is offline
Old 02-27-2007, 09:48 PM   #13 (permalink)
My Photos: (9)
Bean's fuel system does use a Super Duty pump. I have had Bean's fuel system for almost 2 years with no problems. The kit is very well made and put together.
chris
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
SLAPS Treasurer
Member of FOKISD
<font color="red"> #5 </font>
Truck pics at http://community.webshots.com/user/ytee1100
ytee is offline
