Electrical fuel conversion insall - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 12-04-2008, 02:53 AM   #1 (permalink)
JoeDown's Avatar
My Photos: (18)
Electrical fuel conversion install
Now that winter is here I decided to park my truck in the shop to give me something to do in the evenings. I decided there was three things on my to do list. IDM mod, DIY stage Is, and to convert from mechanical to an electrical fuel system. I know that you can buy kits to do this but part of the fun is trying to gather together all the parts you need. Luckily others have done this before so I didn't have to try and figure out what regulator and filters would work. Here is the list of parts I used and the costs.
Prefilter and base - Stanadyne 33640 (thedieselstore.com) $74.64
Secondary Filter Base - (WIX): 24770 (Fleetfilter.com) $26.00
Secondary Filter - (WIX) 33528 (Fleetfilter.com) $9.00
Fuel Pump - (ebay.com) $114
Fuel Lines - Stainless steel 3/8" under turbo (local) $100
Oil pressure switch - Holley 12-810 (amazon.com) $28.00
Fuel pressure switch - (local) $25.00
Fuel regulator - Aeromotive 13109 (ebay.com) $133
Fuel hose - Parker (international dealer) $5.00
Stainless hose clamps - (home depot) $7.00
Fuel pressure guage - (harbor freight) $5.00
Brass three way connector - (harbor freight) $4.00
Fittings misc brass - (harbor freight) $13.00
Fittings - Parker (local) $37.33
Wire - (local) $5.00
Fuel pump bracket - (wrecking yard) $5.00
Misc stuff - (local) $9.00
Total - $600
The first thing I did was remove the stock filter housing and pump. The only thing I left was the fuel lines coming into the valley from the tanks.
I went to a transmission shop and had some custom made 3/8" stainless steel fuel lines to go under the turbo. These attached to the back of the head and came together with a brass three way air connector. I bent the stock lines by hand into the right positions being careful not to kink them. I did not need to cut them to make them fit.
I fabbed a bracket out of stainless steel to mount the pressure regulator to the bracket on top of the HPOP reservoir. I reused the existing flex fuel lines coming from the front of the heads into the fuel regulator.
Electrical fuel conversion insall-030.jpg Electrical fuel conversion insall-133.jpg
The wire for the fuel filter restriction was plugged into the fuel pressure sensor to light the dash light if fuel pressure drops below 20lbs.
I went to the wrecking yard and got a fuse box from an F150 so that I could add another relay and fuse to my fuse box. I added the relay in the upper left corner and the large size 30amp fuse furthest to the right. All wiring was run in existing looms where possible. I wanted this whole setup to look as factory as possible.
96 F350 4x4 XLT 7.3 37,300 orig miles, Stage I's, IDM mod, gutted EBPV, Tymar intake, Banks intercooler, downpipe, gauges, TW 4 position chip, c00nhunterjoe accumulator body mod, Ford 08 alum diff cover, Oil gauge mod, Electric fuel conversion, Durn cat done run off an I can't find it.
It is better to have a lobster on your piano than to have a crab on your organ
JoeDown is offline
Old 12-04-2008, 03:04 AM   #2 (permalink)
JoeDown's Avatar
My Photos: (18)
For the fuel filters I fabbed a couple brackets from stainless and mounted the filters as high up as I could. They are not visible unless you get under the truck. This is only possible on an F350. My F250 doesn't have the depth under the cab in front of the front fuel tank.
I mounted the fuel pump using a bracket from a Ford car that holds the fuel filter. It was just the right size and worked perfect. It might have been easier to just use a SD pump but that would have cost me more.
The oil pressure sensor was installed in the rear oil cooler header. I used a rubber boot from a BMW at the wrecking yard. I was surprised how well it fit.
I also added a fuel safety shutoff switch from another Ford car. I spent quite some time looking in the engine compartment until I realized they were located in the trunk.
Finished it up last night and took it for a spin. All I can say is I've never felt anything like it before! I just wonder how long my tranny is going to last now. I have a TW chip with the street race position but it hasn't been programed for the new Stage 1s I put in. Anyhow all I can say is this is a different truck.
JoeDown is offline
Old 12-06-2008, 06:15 AM   #3 (permalink)
7.3psd's Avatar
Looks like you thought it through and did a nice job. There are a couple things I'd have done different but I applaud you on your keeping the wiring tidy and useing the factory fuse block etc. 99% of guys on here just run wires all over the place and make it look like crap! You did a nice job.
One thing I'd be careful on though is the fuel line going to the heads. The stock supply line is a suction and you have a piece of hose just clamped on there. You need to use some sort of push lock fittings or something that has a more positive hold. Or you could blow the fuel line off of there and have some major spillage issues.
97 F-350 4X4 exhaust, intake, superchips
7.3psd is offline
Old 12-09-2008, 03:53 PM   #4 (permalink)
Cratos's Avatar
My Photos: (15)
what was the part # for the parker fitting to go from 6AN to 5/16 hose barb 90 degree???
97 F-250HD Super Cab 4X4 E4OD, 3.55 gears, swamps 238'/80s & SWAMPS Chip,Beans D-66 Turbo, Adrenaline HPOP & Reservoir Filter, BTS,TSM Disk Rear Brakes,DIY Electric Fuel system,DIY Air Filter,Auto Meter Dash Mounted Gauges: Trans Temp, Boost, EGT, Oil Temp, Oil Pressure.Water Temp,Fuel Pressure Gauges,3 Inch Intake plenums, 4 inch MBRP, Intercooled, CCV mod.
294,000 Miles and still going Strong.
Cratos is offline
Old 12-09-2008, 08:26 PM   #5 (permalink)
I think a lot of us would be interested in the wiring setup. I.E., if there is an accident, would the fuel pump shut off? Could you write a detailed info on your wiring and relays? My fuel system is below.
Dann
My Mods http://community.webshots.com/user/sconure
1996 E-350 , Bean's stage 2 injectors, 3" intake plenums, dual EGT gauge, boost, tranny, fuel pressure gauges.
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 12-11-2008, 01:24 PM   #6 (permalink)
JoeDown's Avatar
My Photos: (18)
Dann
Here is a quick diagram of how I wired the system. I made the connections for the power, ground, and ignition on directly in the fuse box. The only connection not available in the fuse box was the one for the key in the start position. I tapped into the wire going into the firewall.
Since this setup was built and installed by myself using whatever parts I could get, I cannot guarantee the functionality or safety of this setup. I'm sure there are more sophisticated safety methods to do this. I've heard that a lot of people don't like oil pressure switches because of failure but I haven't heard of a replacement that provides the same type of functionality.
Ideally what we want to see is intelligent control of the fuel pump. Turn the key to the on or start position and the pump runs for a few seconds and shuts off if the vehicle is not started. Pump only runs when the vehicle is running. Power to the fuel pump with just key on is a bad idea as far as safety goes.
JoeDown is offline
Old 12-11-2008, 01:44 PM   #7 (permalink)
JoeDown's Avatar
My Photos: (18)
This is the one area where I was unable to really get a nice factory looking connection. I didn't want to cut the stock line and loose the barb on the end so it is in almost direct contact with the barb coming out of the threeway. It would be physically impossible for the hose to come off unless it split or the fittings on the stainless steel lines came undone. If that happened then hopefully that would cause the engine to die from lack of fuel and the oil pressure switch would kill the pump.
JoeDown is offline
Old 12-12-2008, 09:14 AM   #8 (permalink)
Thanks for the diagram, very informative. What is the "C" connection on the ignition switch? Cranking, Starting? If so, then what runs the fuel pump when switch is in On or run position. Sorry, might be a stupid question.
Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 12-12-2008, 03:56 PM   #9 (permalink)
JoeDown's Avatar
My Photos: (18)
Dann
I forgot to label the diagram of the oil pressure switch. The C terminal on the oil pressure switch is what activates the relay to run the pump depending on whether the truck is being started or is already running.
JoeDown is offline
Old 12-13-2008, 01:48 PM   #10 (permalink)
Ok, think I got it. So when cranking in start mode, power goes to the C terminal and when started the oil pressure builds up and the power then comes from the ignition on terminal. After oil pressure builds, the Normally Open terminal becomes closed and makes contact. Seems to me there are only 2 leads going to our oil pressure units. Are you using a different sending unit?
Thanks, Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 12-14-2008, 11:01 AM   #11 (permalink)
Thanks, Dann
yes he is using a different unit it supplies power to pump while chranking only then when engine is running the switch becomes NC and keeps the pump going so if you lose oil psi the pump will shut off
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
Old 04-06-2010, 04:19 PM   #12 (permalink)
just wanna keep this thread around for myself. is there a better way to do that than this stupid response?
1996 PSD 2WD Auto, 190,000 miles
203 TStat, Napa 6637 open air filter
High Torque starter, Bilsteins, Toyo A/Ts, DIY electric fuel
samduket is offline
Old 01-05-2011, 11:16 AM   #13 (permalink)
95powerstroke95's Avatar
just wondering how this set up will work with duel tanks and the selector valve. as far as the fitlers, what micron is recomended befor fuel pump on suction side and same for after the pump on the pressure side. Does anyone know what the superduty pumps are rated at, psi and gph?
06 f-350 ex cab sb lariat fx4 6.0l, auto, 116,000 miles, stock till warranty runs out. gives me time to figure this motor out . Luckly I have this sight to help! Got to say my THANKS ahead of time!
SOLD 95 F-250 xlt PSD ext cab long bed 4x4.265,000 miles and counting, home made intake, edge evo, 3" dp 4" straight pipe, built trans, autometer gauges, boost, trans, pyro, 4in rough country lift w/bf 35x12.50x16.5, Home made E Fuel, Im'a gona miss her.
95powerstroke95 is offline
Old 01-23-2011, 12:42 AM   #14 (permalink)
fastg60's Avatar
What PSI are you running the fuel at?
95 F250
5 spd
123k
fastg60 is offline
