WOW, what a PITA to get out by yourself. I removed the entire front of the truck to make it easier, would have hated to have to lift it over the front of the truck. Now I am just waiting for my rebuilt drop in to arrive so I can transfer my babies over. I will also gut the EBPV, put on the oil rail crossover and put on the 1.0 housing while I am at it. Since I had to put on a new wiring harnes a couple of months ago, I kept the old one and that will be going back with the core so I will have a spare now.
Barry
<font color="red"> I'd Rather be Stroked than Ram'd</font>
1996 F350 4x4 crew cab, ZF 5 speed, long bed, 4:10 gears, ALF4 PCM Code, rebuilt motor at 186,500 miles, <font color="red"> Swamps Babies and 20* HPOP </font> <font color="blue"> Wildman 4 position chip </font> Super Duty Intercooler using GTS Motorsports install kit, Luk cerametalic clutch w/single mass flywheel, Amsoil synthetic tranny fluid, Tymar intake, Hypermax down pipe, Oil rail crossover, 1.0 A/R turbo housing, Diamond Cut Headlights, U.S. Gear Decelerator exhaust brake, Stancor 586-902 GPR. Autometer EGT and Boost guages on A-pillar. AMSOIL dual bypass oil filter, AMSOIL Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil, Shimmed FPR with BB, Permanent clutch bushing fix, Driver seat mod with lumbar fix
Just think, it will easier the next time!
Beat the crap out of the fire wall why you got it out!
Rick H...
__________________ Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp [color:"RED"] RDRCM#20 [/color]
do a good job on teh up pipes while you are there too, anything in teh rear should be checked and replaced now,
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
WOW I can see it being hard if you took the whole front end off. [img]/ubbthreads/images/graemlins/confused.gif[/img]
2006 F250 CrewCab Lariat FX4 6.OH AFE, MBRP SS Cool Duals, Elite SCT, 4 Up the pillar, Bed Rug and Retrax Lockable cover.
1997 F350 CrewCab XLT 4x4. ?hp/?lb-ft Intercooled, BTS Trans, BTS Dual HPOP, Big Full Force Diesel Jectors, Big Turbo, Ford AIC, Rockin S Custom 5 inch Exhaust w/AeroTurbine Muffler, AFE Stage II Intake, Total Diesel Performance 4 Positon Chip, White Face Gauges,
1979 F250 SC Lariat 4X4 5.9 CTD, BTS E40D, Dana 60/Sterling 10.25, SD HydroBoost brakes, 440HP 992lb-ft, Intercooled, BFG All Terrains on Eagle Alloy 102s. Custom Rockin S Dual stack Exhaust system. DDP Stage IV injectors, HTB2 Turbo, Snow Water/Meth injection My Webshots page
That part wasn't too hard since I had taken a lot of it off before when putting my intercooler in. There were a few bolts that were difficult and at least one that broke and will need to be replaced. My main problem was that my driveway is gravel and I had put 3 sheets of plywood down up against the apron of the garage. That lets me use my creeper under the truck. The biggest PITA was after the engine was frea and clear was to then try to pull it up the slight downhill condition of my driveway and up into the garage. Ended up putting a lag bolt in my work bench and with combo of tow strap and come along, was able to pull out far enough to get the engine stand on it. Then lowering the engine to let half the weight sit on the stand and the other half on the hoist, my step-daughters boyfriend was able to pull the hoist while I pushe the engine into the garage.
Barry
