Is there a two speed rear axle available?
Powerstroke 1995 5spd F350 roll-back tow truck. Not sure of the rear end ratio, but it turns 3000rpm at 70mph. I use it for mostly long hauls, so it would be nice to have a 2 speed rear axle to get the revs down to around 2000 at 70 but keep the low end grunt.
There was a recent discussion on this in the towing section below last week.
1996 CC F350XLT SRW auto, 4.10, 2WD. Original owner. 274,000 miles. Tymar intake, BTS @240,000 miles. Cat is taking some time off for testing.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: StarJM</div><div class="ubbcode-body">There was a recent discussion on this in the towing section below last week. </div></div>
Thanks, just found and read that thread. Seems the Gear Vendors unit would be the trick, but it's pricey. It would allow me to keep the rear disc brakes though, which I'm sure I won't find on a 2 speed axle.
Actually, reading through the entire Gear Vendor site, it might be less pricey than it seems. They claim 22-28% fuel savings. At 22%, it would only take about 8500 miles to pay for the unit in fuel savings, assuming $3.25/gallon (I was paying $3.40/gallon 2 days ago on a 900 mile trip)
You may want to ask around to people that have actually towed heavy with a gear vendors. I think you'll find that many have had a lot of breakage and other problems with it. Do some research on the Gear Vendors option as well as the US Gear Overdrive. The US Gear unit seems to have a much better track record.
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
Have you considered just changing the rear end gears? If you never pull and aren't loaded over GVW a set of 3.55 gears and 235/85R16 tires will be enough to get you going, and will help a lot on the highway.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Koala_Motorsport</div><div class="ubbcode-body">Actually, reading through the entire Gear Vendor site, it might be less pricey than it seems. They claim 22-28% fuel savings. At 22%, it would only take about 8500 miles to pay for the unit in fuel savings, assuming $3.25/gallon (I was paying $3.40/gallon 2 days ago on a 900 mile trip)
Thanks for the point in the right direction. </div></div>
You sure about that? Can you show the equations on how you got to that figure? 8500 miles at around 15mpg would cost roughly 2k to fill up, so a 20% savings would be roughly 400?
I've looked at the gear vendors, they seem nice, and would be great if you haul quite a bit and have deep gearing, but seem to be pretty pricey, if it was in the ~2000 range, I think it'd be much more economical.
I don't know about 3.55 on a rollback with two cars or trucks hooked up mite be a dog.
95 F350 cc, 4x4, 5sp with a short shift kit, 3.55LS, D66 turbo, Beans stage 1's inj, modded ped, IDM mod ,hx mod, DPR intercooler, 3" intakes 3" dp, 4" side out, 2piller w/boost&pyro, steering column mount w/hpop gauge, TW chip, AFE stage 1, ccv mod, DIY oil & coolant filter setups, John Deere coolant eye, ORU RSK, Black Centerline wildcats w/Hankook RT03 315-75-16 mt, One day hope to have a RockDog front bumper w/8" Hellas and a CT performance rear bumper/tire carrier, 05 SD front and rear seats.
Trying to find time to install Con O clutch, 17* HPOP Swamps fuel sys, Ford rear diff cover, Blackbird rear disc brake setup.
I have two Kids and they come first...
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JohnDeere9610</div><div class="ubbcode-body">I dont know about a roll back with to cars on doing 70 to ofthen either but thats what he wanted was 70mph @ 2000 rpm.
Not trying to me a smart a$$
Rusty </div></div>
He never said anything about two cars. We have no idea how he is using it.
1996 Town Car
DAMM I just stated that towing with 3.55 mite not the way to go? Sorry if you think I was calling you a smart a$$.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JoeBob1901</div><div class="ubbcode-body">
</div></div>
8500 miles at an average of 7.5 mpg is 1133 gallons. 1133 gallons at $3.40 is $3853. I seem to have dropped the next part of the equation, sorry. 22% of $3853 is $850, so I guess it will actually take 35K miles.... Oh well, thanks for waking me up.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: TECH51</div><div class="ubbcode-body">I don't know about 3.55 on a rollback with two cars or trucks hooked up mite be a dog. </div></div>
Agreed, which is why I don't want to do that. Although, the other option is more power, then taller gears. The Banks kit that adds 250+ lbft of torque is intriguing. That, combined with 3.55 gears will likely give me same acceleration, but better cruising. Right now, the truck takes some work to get it moving with 2 cars on board, which is how I usually run over-the-road.
Hmm, maybe the Banks kit, 3.55 gears AND an overdrive unit... It's only $$$$
