factory keyless entry system, where is the module?
I have a 1996 with factory keyless. I want to try to move it over to the 1994 CC I have. I assume I can just move the module, assuming there is a plug in on the 1994 for the module. Anyone know whre that keyless module is for sure?
Re: factory keyless entry system, where is the module?
the module is under the dash right in line with the cubby hole. so if you look under the dash inline with the cubby it will be right in front of you with three flat connecters plugged in to it two side by side with one centered on top of those two. LIke a 3 man pyramid
__________________ 1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
