Fender Flare Experience? Bushwacker, EGR or Xenon?
I'm looking for comments from folks that have flares, I need about 2" of lip to cover the 305's. Also links to photos would be great!
Diesel Mechanic 28 yrs
Re: Fender Flare Experience? Bushwacker, EGR or Xenon?
Comon guys, I know ther's got to be photos out there!
I have been looking and looking for something I like. I really don't like the roundness to our trucks with a flare on it.
I do however like how the square flares of a gm look. I have gone so far as to grab one off a shelf to see if it can be fit with a little cutting. It will work.
Just another thought.
