I am looking at doing a DIY elec. fuel system. I have Tim's IC & Elec. fuel pump installation info. What filter set up did you guy's go with. Do you realy need a two filter set up.
97 350 CC 170,000 miles
3"Dp 4"Ex 40 Hp DP tow tune
I did the entire electric system on my truck. Personally I think you do need a dual filter setup. One filter pre pump with no smaller than 10 micron rating that is a water seperator (water seperators do not work as well on the pressure side) and one post pump filter with a 2 micron rating. The post pump filter will protect the injectors from debris due to a failing fuel pump and provides even better filtration than possible with a pre-pump filter only setup.
I have a Fleetguard FS1001 filter/water seperator pre-pump, a SD fuel pump, then a NAPA 3528 post-pump filter. Both filters screw on to NAPA filter base number 4770 (2 required)
The 3528 filter is the NAPA equivelant to the CAT 2 micron filter that you see used a lot, I just don't have a good place to get CAT filters.
I have pictues of everything but they have a watermark on them that I doubt will be allowable on this forum.
96 F-350 CC Dually
B codes, head studs, valve springs, 6.0 IC, electric fuel system, Wildman tunes
346.7 hp 12/15/07 Greeley, CO w/ stage 1 injectors
I agree dual filter is best. Too much money in the engine to risk bad filtration... I use a Heated Dahl water/fuel seperator 2 micron prepump, then a NAPA 2 micron spin on post pump. If you go lower than a 10 micron prepump you need to make sure it is designed for high flow rates.
Sam
96 CC F350 SRW - 3" DP - 4-5" exhaust single stack - DIY K&N Intake - coolant filter - secondary fuel filter - rear airbags - Rancho 9's in rear and 5's in front - Pac Brake - 17k Tranny cooler w/ fan - Aux Engine Fan - 1000lb lift gate - jumper cables - Oil temp/coolant temp/boost/pyro gauges - turbo timer - 120 IDM
Soon to be installed Tranny gauge, air horn, Steering Stabilizer, IC, E-350 battery tray/relocate
I will be working on my system tonight after work, I believe that I will be installing everything in my tool box if I go with the Dahl 150, if I go with my Racor 500 series then it will go on the frame. Post pump I have a CAT filter housing with a 2 micron filter. I have gathered up a few different filter's, I have two heated Dahl 150's, two Racor non heated 500 series and a Cat filter housing. I'm not sure if I need the Dahl 150, I like that it is heated, but I'm not sure if I need it. The Racor flows 1.05 gpm that 63gph, I would think that should be plenty. What do you guys think? Thanks
Frank
__________________ http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
