Old 01-13-2006, 02:51 PM   #1 (permalink)
Darth_Stroker's Avatar
My Photos: (6)
Fix for boost gauge flutter
I read a post on here some time ago about introducing restriction into the line to stop the boost gauge flutter, does anyone have a link to the thread or just the info on how to and what to use?
With the stage 2's [img]/ubbthreads/images/graemlins/smokin.gif[/img]and reprogrammed chip it's really boincin' now [img]/ubbthreads/images/graemlins/eek.gif[/img]
97 F350 CC 4x4
BDP Stage 2's, Dominator 66 turbo, 4pos Wildman Chip, BTS Tranny, ATS .95 Wastegated exhaust housing, Hypermax IC and Pipes, comp 910 valve springs, MBRP DP and 4" exhaust, DIY intake, 17 deg SD hpop, Autmometer sport comp boost,pyro,tranny temp, 35" BFG A/T's, Centerline wheels,3.55 LS, Powerslot rotors,hawk pads, gpr bypass,ac mod,fumoto valve,coolant filter,ELC coolant,JD coolant eye,fpr shim,EBPV gut, IDM Mod
Fightin Texas Aggie Class of '98
Darth_Stroker is offline
Old 01-13-2006, 03:14 PM   #2 (permalink)
greenskeeper79's Avatar
Re: Fix for boost gauge flutter
I use a regular $2 automotive fuel filter (the plastic kind with the paper element inside) on both our vehicles...solved the flutter on both as well.
1997 F-250 PSD crew cab shortbox 4x4 E4OD trans 3.55 gears, aftermarket downpipe EBPV gutted, 20.3mpg, 147,xxx miles and climbing (slowly)
1998 VW JETTA TDI (1.9L turbo direct injection diesel) GATOR ECONO CHIP, EGR eliminate, straight pipe, powerplus764 injectors, 55+ miles per gallon! 130,xxx miles and climbing (quickly)
greenskeeper79 is online now
Old 01-13-2006, 04:34 PM   #3 (permalink)
Where did you put it? Do you have a pic? Thanks jordan
96 f350 7.3 206kmiles 4x4 stage 1's downpipe and gagues.
jray3369 is offline
Old 01-13-2006, 04:47 PM   #4 (permalink)
brahamfireman's Avatar
I was dreaming about this the other day also, and was thinking that maybe it is because the map line is so close to the intake valves, that maybe if it was moved to the Y pipe right after the turbo, maybe it would calm it down.
anyone have there's in the Y-pipe, does it still flutter.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 01-13-2006, 06:00 PM   #5 (permalink)
My Photos: (6)
That sounds more simple than the original post I read here some time ago I'll have to try it. I'm assuming that it will still allow enough flow to get an accurate reading. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Looks like I might need to get a 60psi gauge now [img]/ubbthreads/images/graemlins/blush.gif[/img] it seems to be spiking the 35psi gauge, and probably a new turbo and or an intercooler in the near future.
Old 01-13-2006, 07:46 PM   #6 (permalink)
yeah gettin it around 35 psi or more you will need a new turbo, mine is hurting. mine flutters too, but i thought it was the gauge, maybe not. ill try some type of restriction.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 01-13-2006, 09:41 PM   #7 (permalink)
There is an orifice you can stick on the line that should fix it. You can get them here, looks like you need the 0.025" orifice as per Elkoholic's post here. [img]/ubbthreads/images/graemlins/grin.gif[/img]
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 01-13-2006, 10:15 PM   #8 (permalink)
Would it hurt to put it before the map. I was thinking about right before the T?
jray3369 is offline
Old 01-13-2006, 10:19 PM   #9 (permalink)
I don't see why not... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
- Ryan
285HP
ryanPSD is offline
Old 01-13-2006, 10:38 PM   #10 (permalink)
My Photos: (6)
Thanks it's nice to have some options.
That was the thread I was looking for. I need to add every interesting thread to my favorites because it never fails as soon as I need the info I can't find it. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Alan
97 F350 CC 4x4
Old 01-15-2006, 02:49 AM   #11 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
I had a '96 with an Auto Meter z-series 60# boost gauge that didn't flutter at all. But my '95 has an Auto Meter Sport Comp 35# gauge that flutters above 10# of boost. The '96 was in the Intake Y and the '95 is in the MAP line [img]/ubbthreads/images/graemlins/shrug.gif[/img] I still have the 60# gauge and been meanin to try it and see the difference on the truck, but I haven't gotten around to it yet
I noticed that it says operating temps are 40* to 120*, how will that affect it when it is winter?
-Michael
Michael Paul
1995 F250: Regular cab, 7.3L PSD, 5-Speed, 4x4, 4.10 LSD, gauges, 2L chip, injectors, turbo, 4" downpipe - 6" tip, clutch, fuel system, Medium oil, Headstuds, Valvesprings, Cab lights, Dana 60 - New Look Soon!
1995 F250: Regular cab, 7.3L PSD, 5-speed, 4x2, 3.55 open, Intake, Downpipe, 4" exhaust, clutch, 2L chip, short throw shifter - To do list!
My Webshots
Dieselfever78 is offline
Old 01-15-2006, 01:02 PM   #12 (permalink)
You can put the fuel filter somewhere (I don't think it matters exactly where) in-line of the gauge. On both our turbo'd vehicles, I put it under the hood just before the pressure line goes into the firewall.
Both vehicles had flutter, now the both do not - total cost $4+tax.
Try it and I bet it will work!
Old 01-15-2006, 01:39 PM   #13 (permalink)
Do you happen to have a model that the fule filter came off of? Ex. 94 Exploder / Gas Trimmer.. Thank Jordan
jray3369 is offline
Old 01-15-2006, 10:43 PM   #14 (permalink)
My 0-35PSI guage would flutter pretty badly near the top end of the guage, now my 0-60PSI guage doesn't flutter, but I shortened up my map line because I re-did my boost and MAP lines for the new guage. BTW I have Ultra-Lite Auto-meter's if that makes a difference for ya.
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
My Pictures
DD- SILVER 11/97 F350HD XLT RCLB Auto 3.55LS 4x4 OFFROAD
Mods: Redneck straight-pipe, TS/2L Moto chip.
smokyred is offline
Old 01-16-2006, 06:57 PM   #15 (permalink)
NAPA GOLD fuel filter p/n 3011
[image]http://partimages.genpt.com/partimages/1140001.jpg[/image]
