Old 11-21-2006, 08:42 AM   #1 (permalink)
My Photos: (6)
Fluidampr
Anyone running a fluidampr on an OBS? I was thinkin about getting one to try to smooth things out. Any thoughts?
1997 F-250 xl, extended cab, 4X4, 5spd, , autometer boost and pyro gauges, 285/75 liberators, Dana 60 kingpin (freebee), bb fpr, and a big sratch in the paint, bdp stage 1s, dptuner 6 way chip, south bend clutch con o-fe,,,,,,,,,thats all for now.
chainfeed is offline
Old 11-21-2006, 12:04 PM   #2 (permalink)
Re: Fluidampr
chainfeed, I'm glad you brought this up. I posted in the 94-97 General forums about a vibration that my engine has and have yet to find a definate answer to the problem. My harmonic balancer has the rubber protruding out and it does wobble some so I bit the bullet and ordered a Fluidampr yesterday. My engine did not used to have this buzzing type vibration but it seemed to start kind of all of the sudden. I am hoping this fixes my problem and I will post on the rusults when I get it installed in 5 or 6 days.
P.S. I wish I had access to a vibration anylizer so I could better diagnose my problem. There are 4 combustions per revolution x 650 rps at idle = 2600/min. / 60seconds = 43.3/second or 43.3hz. this is close to 60hz a/c house current which drives a hair clipper for example and my vibration frequency seems simular to a hair clipper. [img]/ubbthreads/images/graemlins/eek.gif[/img] Not to mention that a harmonic of 43.3hz would be some even multiple of 43.3hz, i.e. 173.2hz. A simple rotational mass out of balance would be equal to the rpm/60 or 10.8hz at idle, and would be noticably slower in frequency. If my problem is torsional vibration and my calculation are close then maybee my HB is to blame. I could be wrong about all of this so if someone has a strong physics background feel free to correct any of my mistakes.
So anyway Chainfeed, I can answer your question first hand in about a week.
97 cc PSD, Dually E4OD, 4.10, Tymar intake, International water pump w/filter , Amsoil , 3.5" DP, gutted EBPV, SD elec.pump w/ aeromotive reg. fuel system ,5K EOT ,JS IDM, Twildman chip, Gear Vendors, 7.3 Intercooler, 3/8 tranny lines, trucool max, 230k mi. Truck Pics
KCovey is offline
Old 11-21-2006, 12:25 PM   #3 (permalink)
My Photos: (6)
Re: Fluidampr
Cool, I'll hold off on ordering one untill then. My vibration is really annoying, mostly felt in my feet coming up thru the floor. I'm gonna check my stock one later on today to see if the rubber is coming out like you said yours is. Thanks
Old 11-21-2006, 01:18 PM   #4 (permalink)
Re: Fluidampr
chainfeed,
Actually we sell more of the Fluidampr's to OBS 7.3's than newer ones as they generally have more miles and the factory damper is failing. If the rubber is squeezing out more than say 1/8th to 3/16th of an inch be cautious as the outer ring might come off and cause all sorts of issues.
If you need a Fluiddampr call us!
Mark @ DPPI
DIESEL PERFORMANCE PARTS INC. 1-866-455-7788 www.DIESELPERFORMANCEPARTS.COM GUARANTEED PRICES DISTRIBUTOR of MBRP & AFE EXHAUST, EDGE PRODUCTS, SMARTY, AUTO METER, ISSPRO, & DiPRICOL GAUGES, SUPERCHIPS, PREDATOR by DIABLO, AFE FILTERS & INTAKES, PML TRANNY PANS & DIFF COVERS, ARP, FLUIDAMPR, POWERSLOT & HAWK, TS PERFORMANCE, BULLY DOG, AIR DOG FUEL SYSTEMS, BOSCH, SUNCOAST, STANADYNE AND MORE.
Mark Craig is offline
Old 11-21-2006, 04:23 PM   #5 (permalink)
Re: Fluidampr
I have one,but have yet to install it.I run them on my race cars and they do wonders for them on idling smoothly and better throttle response.
Clifford A.Thomas III
Dyno'd 343 hp and 685 ft.lbs. torque #2 tow setting
http://community.webshots.com/user/cliff1972
1996 F250 4x4 Reg Cab,(3rd)rebuilt engine 9/2007.DYI Stage II 170cc,stock turbo,3" dp,ARP mains,open air filter,DP Tuner F5,4 1/2" s.s. exhaust w/ Borala muffler,Joe servo IDM mod,HX MOD,stock E4OD w/ up graded valve body,TCI convertor,4.10 posi,315/75R16 BFG MT's
Waiting to install:stock 6.0 intercooler and DIY hybrid kit
Wanting to buy:head studs, Comp 910,FASS 150/180 and Modded H2E
1964 Impala 468BBC 6.98 at 98 mph in the 1/8th
1969 Nova 408BBC 6.96 at 96mph in the 1/8th
cliff-1972 is offline
Old 11-21-2006, 04:39 PM   #6 (permalink)
GSXRTURBOQUAD's Avatar
Re: Fluidampr
I have one too, from Blackwidow. Still in the box. [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
02 Excursion4X4Limited: Wifes ride(stock)
<span style="color: red"> www.TerminatorEngineering.com, Proud Sponsor of the Diesel Stop.</span>
<span style="color: blue">Terminator High Pressure Oil Systems</span>
http://community.webshots.com/user/gsxrturboquad
SDRCM #7
GSXRTURBOQUAD is offline
Old 11-21-2006, 11:53 PM   #7 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Re: Fluidampr
I heard there isn't enough clearance between the fan and the damper? No one hear said they are using one.
Soaggydogg is offline
Old 11-22-2006, 12:27 AM   #8 (permalink)
Re: Fluidampr
Hmmmmmmmm, I'll have to check that out. I might be ok though, the 97 has a Cyclone. I'll check both tomorrow if I have time. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
SDRCM #7
Old 11-22-2006, 07:48 AM   #9 (permalink)
My Photos: (6)
Re: Fluidampr
If thats true you could just leave the fan off for the winter then put on an electric set up in the spring.
Old 11-22-2006, 08:40 AM   #10 (permalink)
fluidampr's Avatar
Re: Fluidampr
It is true that in some cases our Fluidampr p/n 720211 for the 94-97 7.3L engines does interfere with the fan by about 1/4". In order to correct this issue we have built a threaded spacer to space the fan out about a 1/2". It simply threades on to the end of the water pump shaft and then you thread the fan/clutch assembly onto the spacer.
If anyone has already purchased a Fluidampr and needs the spacer please let me know and I will be happy to send you one. For those of you who have not purchased a Fluidampr for their engine and are waiting for Santa, make sure you order p/n 720221. This part number will include the spacer with the Fluidampr. If anyone can tell me how to attach a picture to my post I could show a picture of the spacer.
If anyone has any questions please let me know
Thanks,
Dan
fluidampr is offline
Old 11-22-2006, 08:46 AM   #11 (permalink)
bbunting's Avatar
Re: Fluidampr
Dan
There are three Black Widow Diesel customers, and you have their information in the email I just sent you. Thanks
My truck BEST ET: 12.89 MPH: 109.24 Pictures
bbunting is offline
Old 11-22-2006, 03:20 PM   #12 (permalink)
Re: Fluidampr
I just measured my 95 and there is 7/8" clearence between fan and the stock dampner and it won't clear. My 97 has a cyclone fan, it will clear. Looks like the fluid damptner is 1 1/4" taller then the stocker. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
There maybe a way out though for the OBS guys. If we get rid of our fan/clutch assembly and replace it with the more advanced SD assembly, this could solve the clearence issue. [img]/ubbthreads/images/graemlins/wink.gif[/img]
SDRCM #7
Old 11-22-2006, 04:29 PM   #13 (permalink)
Re: Fluidampr
[img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Old 11-22-2006, 06:37 PM   #14 (permalink)
STurbo90's Avatar
My Photos: (9)
Re: Fluidampr
Why not try the spacer that Dan(Fluidamper) says is available in his post?
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 11-22-2006, 10:37 PM   #15 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Re: Fluidampr
I had electric fans and they didn't work worth a crap when towing.
