Does anyone know if they got the Fluidampr for our OBS trucks working yet?
The last I had read was that there was interference with the fan and there was not enough room to move the fan forward enough to clear or something to that affect?
I thought I remember seeing a post from someone on here that works for or owns the company stating that they will be coming out with a new one that will work on the OBS trucks?
Anyone have info on this? I guess I could just call them.
Thanks!
Invader
97 F250 XLT SuperCab LB E4OD
Mod's: Tony Wildman 4 page chip, Stealth HPOP, Beans fuel system, JoeServo high voltage IDM, Swamps 175/173 injectors, Hypermax H2E turbo and inter-cooler, open element air filter, Down pipe, open exhaust, exiting in front of rear wheel, with dynomax bullet race muffler. Home made, dual stage, Propane system, ATS TripleLoc billet steel Torque converter. Imperial Shift Kit, BD PressureLok. Mag-Hytec tranny pan and rear cover, ARB air locker in the rear. Cervinis Fiberglass ram air hood ,(part # 112). 4" Superlift lift kit, Air lift air bags with Smart air auto leveling system in the rear, Full instrumentation, Grant steering wheel, on board air system. Putco skins stainless bed rail/tailgate covers. Stainless Nerf bars. Billet front grill and clear lenses all the way around. My Truck Pic's
I am pretty sure that they do have a part number for the OBS now. I'm not sure what it is though. Call them or one of your favorite parts suppliers and you can probably find out.
96 F-350 CC Dually
B codes, head studs, valve springs, 6.0 IC, electric fuel system, Wildman tunes
346.7 hp 12/15/07 Greeley, CO w/ stage 1 injectors
The p/n for the 1994-1997 7.3L engines is 720221. If anyone has any other questions please let me know.
Is that the same one that's used for a Super Duty or has it been redesigned for a 94-97?
What about the clearance issue between the water pump pulley and the fluidampr?
It is actually the same damper as the Super Duty. However we include a spacer that threads on to the end of the water pump shaft to move the fan away from the engine by about an inch. The spacer is the reason why the 94-97 damper is more expensive than the 99-03 damper.
Please let me know if there are any other questions.
Thanks,
Dan
__________________ Dan Oddy Sales Engineer Fluidampr / Vibratech TVD
Thanks,
Dan
I think he means that someone who installed said the OBS water pump pulley was larger diameter then the SD one is and you cannot put the belt on once the dampener was installed?
The spacer just moves the fan itself closer to the radiator to clear the dampener itself? or something else?
Anypower advantage? I too am very interested in this product, but haven't really gotten any feedback. I'm sure it makes the truck run better, but would like to know if spending $400+ bucks is worth it at this point.
97 350 XLT SRW CrewCab, 4X4, 4:10's, Gauges, Tymar OAE, HX hose, 6p chip, no EBPV, ORU RSK, Evans Coolant with inline filter, PLM tranny and diff covers, 203 T-stat, Spin-on in-line trans filter & true cool cooler, 5" exhaust, IDM mod, AC mod, Banks IC, hada PULSE HPOP but a 17 willdue4now, DIY Stage I's, Dieselsite CPR OBS electric fuel system, Gregg Evan's Monster in a BOX!
Yeah, that's exactly what I meant. And I still didn't get an answer.
It fits with your stock water pump pulley, but it's tight. Just need to pinch the belt between the two pulleys while you turn the pulleys(it's that tight!).
I recently replaced my water pump and used the SD pulley this time. Now my water pump turns a bit faster!
Did the Fluidampr help? I think so!
__________________ 95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
I like mine. seems like the engine idles and runs alot smoother. no hard data to back that up but it used to vibrate when idling and now it's smooth as silk. The belt is an issue but I got a sd pulley just haven;t installed it yet.
alan
97 F350 CC 4x4
BDP Stage 2's, Dominator 66 turbo, 4pos Wildman Chip, BTS Tranny, ATS .95 Wastegated exhaust housing, Hypermax IC and Pipes, comp 910 valve springs, MBRP DP and 4" exhaust, DIY intake, 17 deg SD hpop, Autmometer sport comp boost,pyro,tranny temp, 35" BFG A/T's, Centerline wheels,3.55 LS, Powerslot rotors,hawk pads, gpr bypass,ac mod,fumoto valve,coolant filter,ELC coolant,JD coolant eye,fpr shim,EBPV gut, IDM Mod
Well I just placed an order for my Fluidampr. I have alway had a bit of a rough idle and am hoping it will help with that.
GSXRTURBOQUAD,
Do have the part # for that SD pulley? Not sure I am going to use it but would be nice to have the P/N in case I decide to.
Invader
