I am sure everyone here has cussed out ford for their stupid wheel center caps at one time or another,I am beyond sick of the dam things coming off.What has you guys done to remedy the problem without changing wheels?ANyone use the caps that insert from the back and use chrome lug nuts?Anyone have pics of what they did?
thanks GRRRRRRRRRRRRRRRRRRRRRRR
__________________ http://community.webshots.com/user/moooboy
69 Dodge Super Bee,383HP,4 speed,#'s match
70 Barracuda Gran Coupe,383hp,#'s Match
95 F250xlt,PSD,SC,LB,4X4OR,Evo,4"ex,800 watt CD,Homemade Tymar,Rancho 9000's W/ Remote,MM 12k Winch/Cradle,F@R Recievers
Suzuki Vinson 4x4 ATV
Ford 1510 Diesel tractor,4x4,loader
2006 Dodge Magnum SXT
2006 Honda VTX 1800S spec 3
AQHA QuarterHorse,1HP,Very Fast
Mooo,
I sprayed the hubs with the "hammered" finish black paint and replaced the regular nuts with long chrome ones. It worked out ok. I used Mr Lugnut brand nuts. The large od of the taperd portion of the nut wasn't as big as the oem nuts. It has worked but I don't think I would buy that brand of lugnut again.
Dylan
<font color="red">97 F250,RC,XLT,4X4,E4OD,4.10, </font> 116K TYMAR,LINE-X, AUTOCOMAND, GY WORKHORSES, SHOCKS, REBUILT D50, HPOP, OIL PAN "GASKET",ENGINE OUT TWICE, GPR, BLUE FUEL LINES,STARTER,REAR DIFF,ALPINE CD,GUT EBPV,3 SSDP,HPO PLUG,Tru-cool 4950,FUEL HEATER,HPX,SONAX,TRICUMULATOR,Brakes
I also despise the center caps, but they stay on with a liitle dab of blue silicone in each slot that the tabs lock into. Don't overdo it, though, or you will have to beat them off with a hammer.
I feel your pain, caps that install from the back of wheels and longer lugs are the path, but not sure if you can get them for stock rims as mine are aftermarket.
94 cc 350 longbed 5 spd man- fpr shim, home made intake, kitty with no guts,gutted ebpv, fuel heater disconnected, edge evolution programmer, egt guage, redline 80w-140 r. axle, new water pump 11/21/04 Replaced gp on 12/27/04 switched to rotella syn oil on 1/04/05 . replaced uvch and gasket 8/18/05. When in doubt, kill them all and let God sort em out later [img]/ubbthreads/images/graemlins/smile.gif[/img]
OEM wheels are hub-centric, so no room for center caps from the backside. I know of one guy who machined out the center just enough to allow for them.
Best fix for stock caps is to remove wire bail, place each one of the four risers in a vise and very carefully bend them outboard. When reinstalled, this will result in the plastic tabs fitting more tightly on the wheel.
But, it's a fine balance between enough and too much. It is very easy to miss getting one of the tabs inside the wheel notch during installation. They will usually break off completely when that happens.
I use a little grease on the tabs so they slide into the wheel notches more easily.
The design sucks. I've lost several rear caps over the years and broken several of the plastic tabs. I've had the best luck silencing noisy caps by forcing foam insulation into the gap on each side.
try suburbanwheelcover, they have a metal ring that fits over the lug nuts to hold them on,made in taiwan, if you buy check the screws on the inside, i had to glue 2 screws in after a while because they stripped them out at the factory,damn foreign labor. they do not have a ford logo in the center.
As was mentioned the stock wheels are hub centric. And since they are aluminum rims with a hub centric design, you should be using the factory or comparable nuts that have the attached washer to allow the nut to tighten while leaving the washer still against the wheel. little cheesy chrome tapered lugnuts are not a good idea imo. The factory nuts are really good quality. Don't use tapered nuts on an aluminum wheel that is made to be hub centric and not lug centric.
I don't know why you wouldn't like to see the nice and burly full floater peeking out in the rear anyway. Just hit em with some John deere medium gloss and they will look good and the paint will never come off. I'm a big fan of JD black paint by the way. It's the shyt. I've used it for years with unbelievable results.
Go with the Alcoa hub covers, lug nuts, and lug covers. They fit well and look great. Available directly fron Alcoa or I think from Southwest Wheel. Below is a list of the part numbers. Do a search under the user name dtosh and there are pictures in his signature.
Later,
John
2 - #3167 Front Center Caps for 4x4
2 - #8167 Rear Center Caps (Alcoa emblem on center in blue or black)
32 - #5916 Steel Lug Nuts
32 - #78 Lug Covers
Later,
John
32 - #78 Lug Covers
I'll second that, pics in sig.
Dave
__________________ '97 F350 XLT CC, 4x4, SRW, H2E, Modified babys, BTS Trans, Head Studs,,,,,too much to list.
Has anyone tried the later model caps that clamp over the lig nuts as well?
yes and it does work!!!! they are very tight and had to get on and off but work and look great!!!!
97 crew cab short box f250 power stroke 4x4 automatic. 4.10s a stock other an 209500 miles first tank 18mpg, 4in exaust with no kitty or muffler now.
1983 F-350 Crew cab 4x4 4.10 5 speed 90 cummins 12v, turned up pump, centerforce clutch, stright piped,97 alcoa ford wheels, with custom built flatbed 265 85 16s
sold!!!! 96 crew cab short box f250 power stroke 4x4 automatic. 4.10s one wheel wonder 180000 miles, old chip no epv 3in down pipe, 5" STACK custom air cleaner (like tymar) custom bumper 285 85 16's
