Old 12-10-2006, 12:26 PM   #1 (permalink)
trooper2's Avatar
front cover ?
ok does anyone have a front cover that will work or replace my front cover off my 96 don't need HPOP but will take a SD 17* HPOP. or which ones will inter change with my water pump and stuff. ok after checking my parts computer it says everything is the same up too 2003. with that said does anyone the part or know someone that would have one. thanks Jr.
active duty US Coast Guard
SEMPER PARATUS "Always Ready"
96 F250XL supercab ZF5, 4x4, 4.11, 4in exuast turbo back, K&N oper air, edge evo, boost & pryo, 180cc DIY, 2000 intercooler, 315/75/16 Dunlop mud rovers on alum. AR wheels, 2000 SD fuel pump with 2 filters, 17* pump, 3in body lift, AIC, 2 1000cca batteries, custom winch bumper/brush guard, Dodge 40/20/40 cloths seats,
trooper2 is offline
Old 12-10-2006, 06:27 PM   #2 (permalink)
Nit
Re: front cover ?
your 96 will take any HPOP the 95 jsut had a drain back issue that's all, re&re ing the front cover requires an engine pull.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 12-10-2006, 06:35 PM   #3 (permalink)
KRP
Re: front cover ?
I ordered mine from Powerstrokeshop.com they had the best price I could find on one. I got the front cover plus all the gaskets, seals, etc. to do the install for less then I could buy just the front cover anywhere else.
2000 F-250 Ex.Cab 4x4 Auto with Homemade Intake, 4" Exhaust, DP Tuner Chip, Tugger Kit, 2 HPOPs, ITP Fuel System/Boost Regulator, AC injectors, and Van Turbo/WW
KRP is offline
Old 12-10-2006, 10:29 PM   #4 (permalink)
trooper2's Avatar
Re: front cover ?
KRP do you happen too know what the part # was for your front cover on powerstrokeshop.com i can't get it too come up for a diesel. somehow when after removing mine and replaceing the de-aration valve it got cracked where it comes out the drivers side and runs back too the oil fil. i don't know how it happened sense i have too work on it as i go. so im now (always something) needing a front cover no gaskets or HPOP unless its a 17* HPOP for the 180cc injectors. only other thing i can think of doing is getting a welder to weld it. it's just cracked about 2". thanks Jr.
trooper2 is offline
Old 12-10-2006, 11:38 PM   #5 (permalink)
KRP
Re: front cover ?
My front cover is different than your's and I can't find a listing for yours either. Call them and talk to Bob and he should be able to get you what you need.
KRP is offline
Old 12-12-2006, 09:14 PM   #6 (permalink)
Paul H's Avatar
My Photos: (10)
Re: front cover ?
Trooper , did you get to the bottom of the no oil problem?
Paul H
OWNER
2004 Ford F350 6.0L Dualie
1996 Ford F350 7.3L Dualie
FOKISD CLUB MEMBER
FOKISD CLUB SITE WEBMASTER
double U double U double U Dot FOKISD Dot ORG
My Pictures
Paul H is offline
Old 12-13-2006, 08:02 AM   #7 (permalink)
trooper2's Avatar
Re: front cover ?
Paul H. i did get to the no oil prob. the valve was still in place but after removing it and checking it out i most def. think its time was up, it was just a mader of time till someone broke the sill on the oil system. you could blow straight through one side and on the the other side it seemed like it just took more air then it should to get it to seal up and block the air. so i just replaced it with a brass plug put her back together and she fired right up and ran for a lil until i notice water driping from the drivers side as it started to get worse. was then i noticed the some how the lil ear on the drivers low side that goes back to the oil fil. was cracked on the water side. so pulling it all off again and haveing it welded back together. i thinking it should be alright sense theres no high pressure. well that about the brunt of it. thanks for all the help. justin r.
trooper2 is offline
