Old 04-29-2006, 01:43 PM   #1 (permalink)
front differential question
I am doing the ball joints on a D 50 and trying to replace the seals at the differential also. The left side pulls out, the service manual only says seperate at the slip joinr/rubber boot on the right side. should the yoke at the differential pull out or is it retained inside the differential? Thank you
95 250 SC 4x4 auto 4:10 28,000 long cooler shimmed guages pipe WD chip, manual hubs, camper, 22' 5'er horse trailer
Rick Thielmann is offline
Old 04-29-2006, 05:30 PM   #2 (permalink)
gnxtc2's Avatar
Re: front differential question
The passenger side inner stays in. If you want to remove it, you have to take the diff apart. The driver's side slides out.
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, US GEAR downpipe, Bilstein 5150s, Front add-a-leaf w/urethane bushings, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, Shimmed fuel regulator, 4" Exhaust-Straight piped,FORD AIC, Custom triple A-pillar gauge holder,B&M Supercooler, gutted EBPV, B&M Transpan, ART Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, 149K
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 04-29-2006, 09:41 PM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I don't know why they do it that way. The D44 in the 1/2 tons come out after you take a small plate off.
The ones in our trucks don't come apart that easy.
MarkEkberg is offline
