While I'm doing the obligatory search for the subject, can anybody tell me a decent brand and size of speakers to replace the POS's in the front doors of our trucks? After ten years, I finally got one of those newfangled stereos that plays those compact disk thangs and promptly blew the front right speaker out. If I'm going to be a bada** bumping my Chris Ledoux ( may he rest in peace) down the road, I've got to have the goods.
Mike
<font color="red">FIRST PICS OF MY WRECK,</font><font color="brown"> THE DESTRUCTION OF A FORD DUALLY,</font><font color="red">[img]/ubbthreads/images/graemlins/frown.gif[/img] ARE BELOW IN "My Pics"</font>
1996 F350 XLT crewcab dually, pullin a 50+3' step deck
1996 F250 XLT crewcab (wife's), pullin a bed full of milk meters and a 27' 5th wheel
<font color="aquamarine">My Pics</font>
<font color="blue"> I PREFER DANGEROUS FREEDOM TO PEACEFUL SLAVERY</font>-Thomas Jefferson
<font color="blue"> Remainder of signature deleted for political correctness violations</font>
ive got some clarions in the front of my truck blasting the same tunes been happy with them and if i remember correctly they wernt too expensive either
97 F250HD 4X4 210K MI
4 LINKED FRONT AND REAR ON AIR
I put 6.5" Bazooka 2-way speakers in my doors. I had to trim out the speaker hole about 1/8" all the way around with tinsnips as they were a little bigger than the stockers I pulled out.
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s, D60 swap, straight pipe, turned up fuel screw
go onto crutchfield.com and order a set of 6.5" speakers. i order all my audio stuff from there because they have the best customer service and supply all the necessary installation accessories for free. they also have a huge selection with various price ranges.
1996 F-350 XLT CC, 4x4, E4OD, 4.10, BD 3" downpipe, TYMAR intake, 5" over the axle exhaust, JS IDM, BDP Stage I Injectors, 6 position chip, PS 2000, Autometer Guages in A-Pillar, Pizza Cutters ... homepage?
Another Ledoux fan? Wow I am impressed. I even called my local station and complained that they did not say or do anything about it.
Anyhow if you get 6.5" 3 ways it will be a vast improvement in sound, but you will have to trim the existing ring in about 4 places and bend the tabs in to get them to fit. if you unwilling to do that all you can get is crapy factory sound.
not all 6.5" speakers need trimming. just enter your vehicle type in on crutchfield.com and it will tell you which speakers will fit without modifications. i have kenwood's currently, but used to have sony x-plods, both of which did not require modification.
I was fortunate enough to see Chris Ledoux's last concert....He was in Kansas City at Kemper Arena during the American Royal in November...I've still got my ticket stub too!! (Might Ebay that someday!!)
On topic: I drove my truck to the concert and had no problems!!
TFB
Sold: 1997 F-350 CC 4x4
"New Rig" 2003 F-250 Lariat CC 6.0L EDGE w/Attitude Monitor, Automatic, 4" Exhaust Truck PicturesShow Me DJ Service
I have the speaker numbers in my sig. they are Pioneer TS-A1671R 6 1/2" 3 way that have the poly cones with rubber surround and handle 220 watts and did not have to be cut to fit. I love the sound from them over the stock speakers. I got these at BestBuy but I think Walmart sells them too for less.
Rick:Red 97 F350 CC DRW 4.10/LS E4OD, 28,000GVW trans cooler w/170F thermostat, remote ATF filter, Mobil 1 ATF, Sonnax valve & Tricum springs, Tymar Hi Performance Open Air Intake System W/Donaldson B085011 filter, IH water pump w/integrated coolant filter, BD downpipe & BD 4" cat back exhaust, "SWAMPED", Tymar HX mod, Tymar/Bill's 4 posn. "flip-chip" (this bad boy rocks), Isspro EV gages in 3 hole PITA Pod, "Harpooned" Fuel tanks, Bilstein shocks, Gutted EBPV, Alpine CDA-9825 head unit, Pioneer TS-A1671R 6 1/2" 220W Front, Pioneer TS-A6880R 6"X8" 240W rear, FOKISD member, Beavercreek, Ohio (near Dayton)
Get some boston acoustic speakers all the way around. The mid range and highs are awsome. Put in an amp and a sub to bring up the lows. This combo sounds really good with LeDuex.
Curt
1997 F350 cc/lb, 4x4, E4OD, 4.10, Pyro/Trans Temp/Boost Gauges. Torn apart- installing h2e, sd intercooler, bronco tank, bosch 044 fuel pump, dahl 150, regulated return, big oil, b codes.
Thanks for all the info guys, I got my stereo from Crutchfield but wanted to make sure their dimensions were right.The problem I was seeing is that they say that everything from a 5 and a quarter to a 6.5 will fit and I figured that either one was going to be too small or the other was going to require some door panel modification.
As far as Ledoux,
Ekberg, don't feel bad, most of the stations down here won't even play him and if you actually call up and request a song you've got a better chance of getting them to play Kid Rock than Ledoux.....
He was a good guy and it sucks that he's gone but he dang sure still fills the air around me with good music on a regular basis. [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
Mike
In addition to the Kenwoods, Cerwin-Vega and Infinitys fit without trimming, just need to drill different mounting holes. Got all of them from Crutchfields.
I also got mine from crutchfield.com I don't even recall what kind they are but they have held up much better than the stockers. Right after I upgraded my stock unit to a high power unit the stock speakers blew. Be sure to also get the wiring harness adapters when you order the speakers so you don't have to hack up the stock wiring.
Off topic: what happened to Chris Ledoux? I must live in a cave..
The infinity 6.1's fit right in with no problems and no modifications either.
LeDoux passed away a couple of months ago, liver problems.
1995 F 350 CC PSD 4X4, 4.10's with E4OD. DIY open element air intake. DPP Downpipe. 10K mod, Fumoto drain valve, SCMT 1705, Shimmed FPR, Stancor GP thingy. BDP Stg I's. Panasonic HU feeding an Orion 800.2 for the two 12" JL's and an Orion XTR400.4 for the Infinity 6.1's Yeah its a diesel but I cant hear it from inside the cab. 5 " open exhaust is installed, she barks now! Isspro Trans,Pyro & Boost on the A pillar. Tru-Cool 28,000# stacked plate trans cooler. bdp Stg I's and a UCC TC and Trans-go Tugger kit to hold it to the ground.
Purchased 9/29/03 @ 108,000 mi
As of 12/25/05 its @ 160,000 mi
Upcoming mods- ?
Also play with a '65 Mustang "ground upped" and a customized 92 Harley. Life is good.
Thanks for the info on the harnesses Crumm. I know you're probably a little behind the times up there so FYI, he died March 9 of a form of cancer of the bile duct. Sucks but he done did good in his life so we should all celebrate it.
By the way, as per the Governor of Wyoming, 30July05 has been officially declared to be Chris Ledoux Day in Wyoming. It happens to concide with the last Saturday of Frontier Days so I'll see ya'll up there.
By the way, we've got a new president as well, it's a dude from Connetticutt ( or however you spell that friggin word) named George Bush. I'll stop there so the post doesn't get yanked but thought I'd let you know so you can spread the word..... [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Mike
