Was wondering what types of fuel additive every one is using?Is there any that help combat the high fuel prices.also what about bio fuel any one making their own?
I use Power Service in the white bottle with Cetane boost. 400:1 ratio , very cheap and simple to use for me . I would love to use Staynadyne Performance but they rape me on the shipping rates and here in T.O they want like 5-6 bucks at the Diesel places. The Power Service ends up costing like a buck -fifty per Tank so I use it.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
I use the powerservice in the Gray bottle. Should i use the white bottle, what is the difference? I used to use Amsoil but even with my dealer discount it got pricey.
Jon
1996 F-250 4x4 extended cab 5spd
4" lift with 37" humvee tires, RS 9000 XL 9 way shocks, 5' ladder bars
6 pos chip pyro and boost gauge, 4" turbo back exhaust, tymar intake, 17 HPOP, shimmed FPR
solid steel front bumper, in bed 90 gallon tank
car 2
1963 ford thunderbird
work in progress C-6 and mild built 390 planned
I have been mixing half Grey Power Service and half Walmart Super Tech 2-stroke oil and add 1 ounce/gallon. I am going to start using straight 2-stroke oil as Power service is getting more expensive. It really quitens down the motor and runs fine.
97'F250HD XLT 4X4 3" DP, straight exhaust, Edge Programmer, E4od 3.55, VDO pyro, Auto Meter tranny and boost gauges ,Tymar filter, Tru-Cool 4590, EBP sensor eliminator, Rebuilt tranny with PI 4R100 torque converter, shimmed FPR with #4-40 SHCS, Bean's Stage 1, ccv Mod, 6.0 intercooler with Banks pipes.
i run super-tec marine 2 stroke oil 1 oz per gallon runs quieter and saw 2 mile increases in fuel mileage it also seems to help keep egts a little cooler (just an observation)
02 f250 4x4 w/ a 7.3 it has a 4in exhaust from the turbo back, s&b cold air intake, hyper junk stage 3 programmer, idm mod, foil delete mod w/ polished boost tubes, fuel cross over, hpx line, torque converter lock up mod, cvc mod, magnatec trans pan 4qrt over, 6in lift w/ 315 75 r16 bfg all terrains.
I use Stanadyne blue cetane and low ash 2 cycle oil. Last rear tank used just the 2 stroke oil and got 22 mpg mixed hiway (mostly) under (< 2000 RPM) and city driving...will be comparing the Stanadyne and 2 stroke this tank to see if there is any difference. Someone claimed it was counter productive to use the Stanadyne AND 2 stroke oil and that is why I just tried the above.
jrc
96 XLT F350 CC ZF-5 355's 16x8 aluminum rims 285/75R 16 Dick Cepek F-C IIs. T Wildman programs, Map regulator, DIY CCV & HX mod, TDS exhaust brake, BD gauges, downpipe 4" exhaust, custom SS resonator, LUK, SD I/C, Custom Shackle Reversal, Custom Moose Bar and Velvet rides, RS 9000x shocks, Custom Aluminum Drybox/fuel tank, Swamp's Baby Injectors, SD Hpop, DIY Oil by pass filtration, DIY electric fans, DIY E-Fuel system, Lighting by VisionX, LightForce and PIAA and other stuff. http://community.webshots.com/user/jcart44
I read on another forum about using Power Service and Marvel Mystery Oil together in a 2:1 ratio anyone else do this??
No...and unless Marvel Mystery Oil is ash free I wouldn't run it as an additive with your Power Service. The reason people are using Marine 2 cycle oil is because it is ash free. Just my two cents.
Griz
95 F250, 4X4, E4OD, 4.10, Hypermax DP and Tymar 4" Exhaust System, Tymar Air & Coolant Filters and HPX Kit, Tymar fuel fill mod, External Transmission Filter, Schaeffer's ATF. Add-a-leaf, Redline Differential gear oil and Redline ATF in Transfer Case. OilGuard By-pass oil filter. Schaeffer's 5W-40 in the engine. A-Pillar...Autometer Boost, Pyrometer and Trans. Temp. Gages, Under dash...Oil Pressure and Water Temperature gages, 1705 Superchip Tuner, Stancor GPR, Factory Tech Valve Body, Evans Waterless Coolant, Two 4590 Tru-Cool Transmission Cooler in series, Explorer Overhead Console, Diesel Turbo Lifesaver, Tymar Fuel Filler Mod.
yea heard mention of the ASH issue too. Where does the ash come into play at?? Is it on the injectors, in the cylinders, or what??
I would say if the 2 cycle oil has ash then you would start seeing ash deposits on the injector tips and cylinder walls. This just seems logical to me.
Griz
