Old 12-04-2008, 02:42 PM   #1 (permalink)
Send a message via AIM to rockets10510
fuel heater mod
looking for the write up that shows how to do the fuel heater mod?
thanks anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 267,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
1997 Ford F350 2WD SRW Green Crew cab 236,xxx miles, AFE exhaust, oil bypass, coolant filter, intercooler, 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
Old 12-04-2008, 02:48 PM   #2 (permalink)
thanks anthony
The One from "JOAT" isn't available right now ,,,someone else may have done it though...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
racerxautomotive.com
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 12-04-2008, 04:04 PM   #3 (permalink)
4micaman's Avatar
It's been that way a little while too. Always getting a time out when trying to read up on some stuff.
Do you know him, Rick? I'm about to renew my hosting and would be willing to share some space/transfer with him.
-Steve
'95 F-250 Ext. Cab long bed 7.3L 4:11 2WD
135,165 (11/09/08)
137,560 (01/24/09)
IDM Mod, HPX
Technical Publications
4micaman is offline
Old 12-04-2008, 05:17 PM   #4 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
I believe that all the mod does is replace the 94-97 fuel bowl heater with the one from the 99+'s. There are a couple of things that need to be done with the OBS bowl but I do not remember just what they were.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is online now
Old 12-04-2008, 06:20 PM   #5 (permalink)
You have to grind some boss off inside the bowl to fit the newer heater. That stopped me because I don't care to grind my bowl. After 2 failures of the original type, I just removed mine. Even at 10 below have had no problems. If you live in Texas for sure you don't even need the heater.
Ron Hansen, 1997 F350CC, 4x4, PSD 110,000 miles all stock with stupid auto transmission unfortunately. 1993 Ford E350 Club Wagon 7.5L 11,000 miles, 1978 Kawasaki KZ650 motorcycle with 167,000 miles!
RonKZ650 is offline
Old 12-04-2008, 07:38 PM   #6 (permalink)
PSDfreak's Avatar
x2
Ive been down to about 5*F for extended periods and been fine
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio● ALLFF BRAH!
PSDfreak is offline
Old 12-09-2008, 11:03 PM   #7 (permalink)
I did mine without any mods. a little tricky getting it to lay right and get the wire hooked but it does fit!
1997 CC SRW SB 4X4 Auto; 3"DP, 265/75 tires; Fold-A-Cover; Rhino Liner; Edge Evolution programmer; AutoMeter PYRO 17MGP@71MPH; 4:11's; Velvet rides
mikerocchio is offline
