Old 01-07-2007, 08:55 PM   #1 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
Fuel Pressure Gauge
I have doing some research and was wondering what exactly i need to put a fuel pressure gauge on my truck. If anybody has done this and knows how to, I would greatly appreciate it. Thanks!
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
Old 01-07-2007, 10:12 PM   #2 (permalink)
Re: Fuel Pressure Gauge
On the side of the filter housing there is a schrader valve. Remove the valve,insert whatever you need for a hose attetchment, add a dampner from a hydralic shop and install a pressure guage. You will find excessive flucuation in pressure readings is why the dampner is used.
I just had a fuel leak on my vehicle and it was the WIF sender. I already did the change 3 years ago and was to cheap to buy another one. I installed a pressure sender in that 1/8 pipe thread location and tried an electric guage. I just hooked the wireds up. Got 12 psi. Someone from the other forum said this MIGHT be what is in the fuel filter itself, not necessary what the engine has as the schrader valve is basically 50+ pressure on the secondary side of the fuel pump. I have not had any confirmation on ths pressure reading as I don't think anyone has ever thought of installing a pressure sender in the WIF sender location. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 22 ft. Komfort 5th wheel/sold, 170k mi.
Death leaves a heart ache no one can heal, Love leaves a memory no one can steal. -robert ingersol-
Candi 08/14/07
Gone Fishen is offline
Old 01-08-2007, 12:13 AM   #3 (permalink)
brahamfireman's Avatar
that is correct the filter is on the low pressure side of the pump, after the fuel goes through the filter it goes back to the pump where it is raised to 50-70PSI, and into the heads.
like stated before use the schrader valve and a presure snubber for the guage the pressure spikes will kill a gauge within a year and then you will have one for fuel leak to deal with. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 01-08-2007, 12:28 AM   #4 (permalink)
My Photos: (6)
So if I do this will it the readings tell me if my oil pump is trying to die off? It seems like my oil pump might be wanting to die off, or its an injector? Thanks!
Old 01-08-2007, 12:53 AM   #5 (permalink)
BlueMule's Avatar
My Photos: (12)
Nope, a fuel pressure gauge has nothing to do with your oil pressure. If you want to check the hpop oil pressure you'll need a 3000 psi glycerine filled gauge hooked up to the oil rails in the head.
BlueMule is offline
Old 01-08-2007, 09:10 AM   #6 (permalink)
My Photos: (6)
Thank you! This is what ive been wanting to hear. Bluemule do you know how i would go about doing this with parts etc? THanks
Old 01-08-2007, 11:22 PM   #7 (permalink)
you will need a #5 JIC fitting for the rail in the head, a HIGH pressure hose 5K PSI and a liquid filled gauge, also 5K.
Look in my webshots on the '97 I have an external HPOP gauge on the truck, last three pics I believe.
I also had one made at Napa for trouble shooting but the hose isn't long enough to reach out of the hood. same basic parts, fitting, hose and gauge.
Diesel Rod
Old 01-08-2007, 11:46 PM   #8 (permalink)
My Photos: (6)
Thanks guys
Old 01-08-2007, 11:58 PM   #9 (permalink)
My Photos: (6)
Does anybody have any pics were it is located on the engine to pick up the pressure?
