anyone know where I can find a pressure snubber for our fuel systems. I had a mechanical gauge right on the fuel regulator and the pressure spikes killed it in a few months. now I want an in cab one and I need to find a snubber so I dont kill the Isspro incab one.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me. '86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
1. Get an electric fuel pump [img]/ubbthreads/images/graemlins/tongue.gif[/img]
2. Coil up a bunch of extra hose under the hood to damp it out (maybe an extra 10-15'. Depends on what kind of hose you are using as to how expensive this option is.
3. You can get something like a ball/gate valve and put that in the hose line and close it almost all of the way. Or any other kind of restrictor would work too.
To put it in the cab, you'll want an isolator so you don't end up with a 70 lb spray of fuel in the cab if you sprng a leak. I believe autometer has one.
Curt
1997 F350 cc/lb, 4x4, E4OD, 4.10, Pyro/Trans Temp/Boost Gauges. Torn apart- installing h2e, sd intercooler, bronco tank, bosch 044 fuel pump, dahl 150, regulated return, big oil, b codes.
Try Northern Tool, or maybe even Tractor Supply. Surplus Center may have them as well.
Worst case, look in the yellow pages for hydraulic folks, such as Air and Hydraulics, or Southern Fluidpower, any shop that sells hydraulic equipment should have one. I believe Parker makes one that has an isolating valve combined with a snubber. Shouldn't cost too much.
'94 F250 supercab 4x4, original owner, 4.10LS, shimmed FPR, Tymar air intake, DP Tuners 80 Econo burn, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
When I still had the stock fuel system I purchased a snubber from McMaster-Carr, they are an industrial supply house kinda like Grainger. If I remember correctly they are in Chicago.
Chris
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
sweet, thanks guys I will have to do some looking around now that I know where to look.
Diesel Rod
Hey I am just putting in my .02 but I dont think you want to run a mechanical fuel pressure gauge in your cab as if it ever breaks that woudl be BAD. ALso it is illegal as all mechanical gauges have warning as to not put them in cab. Your best option I think is to get an electrical one that way changes wont take it out anyway and safer, just a little spendier.
1995 f350 five speed with 293,000 miles. Autometer silver Pro-Comp gauges, AA injectors, custom built regulated return fuel system, a TP38 hybrid turbo home built, a Tony Wildman chip, stock airbox that has been modified, and dual exhaust from the downpipe with 5 in stacks, and a 99 intercooler. Not fast enough. YET
I did not totaly read your first post, sorry. Like others are saying you do not want to put mech. gauges in cab. When I used the the snubber and mech. gauge it was underhood. I now have an electric gauge in the cab with a sender under the hood. Autometer makes a electric gauge setup but it is pretty expensive, about 190.00.
Chris
Absolutely! Back in the 70's had a mechanical oil pressure in my VW Rabbit. Tubing fatigued and cracked at the nut on the back of the gauge. Talk about a mess [img]/ubbthreads/images/graemlins/crazy.gif[/img]
