fuel system - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 08-27-2007, 12:19 AM   #1 (permalink)
olred07's Avatar
My Photos: (14)
fuel system
will the beans fuel system work on a truck with stock injectors and stock turbo? if not where could i get a fuel system wiring harness for stock fuel system?
Stephen Winzenried-07 f-350 four-door,crew cab,4X4,long bed,Zoodadd mod,4-inch Diamond-Eye exhaust,6-inch tip, SCT tuner, ARP head studs, isspro: trans,EGT,and boost guages ,2.5-inch Sky-Jacker leveling kit,and 35in.BFG's///96 f-250 ext.cab,long bed,4x4,tymar intake,straight 4-inch diamond-eye exhaust,LUK solid-mass flywheel & clutch, edge evo, shimmed fpr, ccv mod,gutted EBPV, auto-meter EGT gauge,ranch-hands front & back,4-inch Sky-Jacker lift in the front,with firestone airbags in the back,and 33in.BFG's.
olred07 is offline   Reply With Quote
Old 08-27-2007, 02:30 AM   #2 (permalink)
Re: fuel system
Bean's SD based fuel system will work on any OBS truck. Just have to decide whether or not its worth it. If you do a search for Tom S or TimC63 you can find out how to do it for less cost. Or PM them and they can refer you to their posts. Bean's uses some premium filter system components and other parts that drive the cost of his system up and there are less expensive options available if you do it yourself without shortcutting the quality filtration aspect.
Dave Murakami 97 F-250 XLT Supercab PSD OffRoad, Bilsteins, Warn manuals, Rhinoliner, Bridgestone 285's, molded steps, smittybilt grille guard w/frame braces, Cibie driving lights, power rear window, Sony CD changer w/infinitys+basslink subwoofer, Tekonsha Prodigy, Snugtop, Reunel stainless steel rear bumper w/Warn HS9500 winch/PIAA backup lights, TFI, 7500lbs, 14.508 1/4, 408 rwhp/#2only, banks powerpack, gutted ebpv, 4" duals, map pressure regulator, JSidm, BTS, maddog stage II ABs, Bean's fuel system, Terminator, dieselpower tri-chip, tymared, black intake, non-fluttering Isspro EVs, almost stock!
masami is offline   Reply With Quote
Old 08-27-2007, 07:23 AM   #3 (permalink)
olred07's Avatar
My Photos: (14)
Re: fuel system
but will it push to much fuel to the stock injectors and cause heat.
Old 08-27-2007, 10:11 AM   #4 (permalink)
Re: fuel system
It can't push to much fuel. Regulated return system on these trucks.
The OBS fuel system is a regulated return system, so heat isn't much of a problem at all. I think it was ITP that experimented and showed that the fuel cooler didn't change the temp by more that 2-3 deg F.
'96 F250 XLT, PSD, 4x4, ExtCab, LB, Auto, 3.55.
11-06: DIY Open Element, EBPV & TC exhaust brake.
02-07: 40 gal '05 F550 aft-axle tank = ~60 gal total.
03-07BTS downpipe & 6pos chip.
04-07: ]226,000mi 277HP, 543TQ, Graph
05-07: EGT, Boost, Trans from Tymar
06-07: 4" exhaust, 31 row 6.0L trans cooler
08-07: BTS Transmission.[/url]
09-07: 80.76 @ 16.527
My picture & diagrams
danjreed is offline   Reply With Quote
Old 08-27-2007, 03:11 PM   #5 (permalink)
olred07's Avatar
My Photos: (14)
Re: fuel system
is the beans fuel system the best and if so how hard is it to install?
Old 08-27-2007, 05:01 PM   #6 (permalink)
Re: fuel system
yea other than $150 what is the diff between swamps and beans
1996 f-250:115000miles,h2e,6.0 ic,3" intakes,studs,beefed-up e4od,4.10ls,add-a-leaf,straight pipe to one 5" stack,guages,diy intake,ccv mod,17*hpop,315/75r16 buckshots,170cc stage 2 diy injectors,wildman 4 pos. chip,timbrens
1969 mach 1 mustang
1965 Ford 4000 tractor:cone filter, 3.5" stack, mack truck nozzles(220cc), pump turned up
Sophmore at Bridgewater College
CURSURI SUMMUS NUDI!! latin for we're going streakin!!
http://community.webshots.com/user/machdriver69
jasonlambert is offline   Reply With Quote
Old 08-27-2007, 07:57 PM   #7 (permalink)
BlueMule's Avatar
My Photos: (12)
Re: fuel system
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: powerstrokenstang</div><div class="ubbcode-body">yea other than $150 what is the diff between swamps and beans </div></div>
I dont know. I cant find any info abouts Swamps system.
BlueMule is offline   Reply With Quote
Old 08-27-2007, 09:09 PM   #8 (permalink)
Re: fuel system
that is my problem too i guess i will just have to call them i am looking at gettin one but i would like some info on both ya know
1969 mach 1 mustang
Old 08-27-2007, 11:21 PM   #9 (permalink)
Re: fuel system
don't mean to hijack but does anyone know where i can buy replacement filters for beans system? mine are plugged and i can't start the truck
My F-250 HD
1997 PSD F-250 HD 2wd ex-cab longbed prerunner. 4.10 LS rear. Edge Evolution. BDP electric fuel system. 3'' downpipe to 4'' out. 0.84 Turbo Housing. HPX mod. Gutted EBPV. Tymar intake. 3rd E4OD. B&M deep transmission pan. 4'' Fabtech lift on 35s. Bedcage toolmounts. Prerunner bumper with skidplate. SS brake lines. Flipped steering stabilizers
thegreg92 is offline   Reply With Quote
Old 08-27-2007, 11:35 PM   #11 (permalink)
Re: fuel system
do you happen to have a part number? and price?
My F-250 HD
Old 08-27-2007, 11:43 PM   #13 (permalink)
Re: fuel system
thanks i appreciate your help. in the meantime i have been stuck driving a gas truck [img]/forums/images/%%GRAEMLIN_URL%%/frown.gif[/img]
My F-250 HD
Old 08-27-2007, 11:48 PM   #14 (permalink)
BlueMule's Avatar
My Photos: (12)
Re: fuel system
Well its in a plain brown box with no markings and I cant find the receipt. But it was 30 something.
I just told them the Stanadyne number (533911) and they crossed it over to a NAPA number, the filter I got has the stanadyne number on it
Ive got an extra filter. Do you want to use it and then you can replace it when you get one?
