I have a question, about our fuel tanks. Is the plate that holds the pick up and return lines steel or pastic or some other material? [img]/ubbthreads/images/graemlins/shrug.gif[/img]TIA, Carl.
97 F-350,4wd,cc,long bed,4.10,35's,rebuilt E40D,H2E,3" intakes,Head studs,,pyrometer,boost,trans temp,home made open intake,Joe servo IDM, Inner cooler retro,Baby swamps 170/146, Bills 3 position chip,Updated HPOP, home made oil bypass filter system, A/C mod, updated super duty fuel system, 60 gal/toobox combo.
We drill a big hole in the plate and put in a 5/8" JIC (-10AN) bulkhead fitting and pickup tube on our fuel systems, and then we plug off the factory return line and use the supply line for the return.
Jonathan
The Swamp Donkey: 1995 F-250 4x4 with 2.5 ton military drivetrain, 49" 14.00x20 Michelins, dual 5-speed trannys feeding NP-205 X-case and 1410/1580 U-joints. Engine & trannys are out getting rebuild #2...hmm...I wonder what I can do to it now?
