Old 04-29-2008, 01:01 PM   #1 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Fuel tanks again
I replaced my rear tank about 5 years ago due to rust through.
Guess what? The dumb thing is leaking again.
I am going to go bronco tank this time, but my question is if they make a plastic tank that I can afford?
MarkEkberg is offline
Old 04-29-2008, 01:10 PM   #2 (permalink)
Rusting?
Is it rusting from the outside or inside?
2003, F250, Super Duty, Super Cab, 7.3, Auto, 4X4 Silver, 2" lift in front only, 46 gal fuel tank, Billet Grill, 285X75X16 BFG MT, Bilsteins, Firestone Air Rear, B&W Gooseneck, We call it the "Silver Knocker"
reba is offline
Old 04-29-2008, 02:40 PM   #5 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I will use the stock skid plate. I am not sure how this one rusted? Last one rusted outside in where a pebble was wedged between the skid plate and the tank.
Old 04-29-2008, 03:37 PM   #6 (permalink)
moonshiner's Avatar
check out aerotanks.com
they have a 45gal aft tank that is ready to bolt up and comes with everything for $384
If it dont burn, it aint good!
1996 F250 4x4 S/C LB, 4.10, Tymar Intake, 4" Strait-Pipe, Marsh E40D, 4" Lift, 35" Pro-Comp Xtreme-Mudders on 16x8 Steelies, 190K miles, TW Chip, Rose 160cc injectors, SD CAC, D66, 2" Rear Aluminum Spacers, Dana 60 Front w/ LockRight Locker
On The List: Oil, Tank, Fuel, Lockers, Modular Flatbed
moonshiner is offline
Old 04-29-2008, 08:14 PM   #7 (permalink)
Did you spray the last one with a good layer of undercoating? I've found that helps to stop rust pretty well. It might help with pebbles too. I replaced my forward tank last spring and all I could find was a bunch of pebbles in the rubber boot that goes over the front of it. I used a lot of undercoat so I'm hoping it will work.
'94 F250xlt ext. cab. ZF5-speed 4x4. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. LF777 bypass oil filter. Electric fans. 70 psi fpr. 10k mod. 1.0 turbo housing. Boost blanket.
sdan27 is offline
Old 04-29-2008, 08:35 PM   #8 (permalink)
Hey, Mark!!!
Mark, a few years ago, I did some "upgrading" to my fuel system, and went with one 33 gallon plastic Bronco tank (from the Bronco Graveyard mentioned above), a couple of fuel filters in between the tank & the fuel pump, the Aeromotive regulator deal & all that. I bought a used Bronco skid plate at a wrecking yard for around $25 that I used for that plastic tank.
The Bronco skid plate was about 2 or 3 inches to short to bolt solidly up to the frame, even though the bolt pattern was fairly close. I initially used 3/8" all thread to take up the room between the skid plate & the frame, like another member here had done back years ago.
After the tank had been on for at least a year or two, and been over some rough roads all over Oregon, I was driving to work one morning, bounced across an intersection with a full tank, and the all thread broke!!! I was dragging my tank, on the skid plate, by my pickup & return lines....
I fabbed up some wonderful steel brackets from mild steel flat bar with my newly purchased mig welder, to go between the frame & skid plate, and never looked back. Mostly 'cause my tank stayed up where it's supposed to be....... A guy sure appreciates little things like that....
The big tank in back means some work & "concessions" on your part. I had to lengthen & modify my fuel pickup tube quite a bit, and engineer up/lengthen my fuel sender float, get it adjusted (that took a couple of tries to get where I liked it- reading empty with around 4 gallons of fuel left), and then making a bracket for the spare tire to ride in the bed.
If you've already addressed this kinda stuff, forgive me. I just want a person to be aware of all the stuff that either needs to be done, should be done better than how I did it, and that it probably ain't a simple bolt-on kinda deal, if you want any sorta longevity of the components....
Best Fishes,
Jimmie
Best Fishes,
Jimmie Newton
'97 Crew Cab (The Figmobile...Reloaded). XLT, 4X4, E4OD, 3:55s, NAW6 PCM Code, Gutted EBPV, "Butchered" Turbo Pedestal, 1.0 Turbo Housing, 3"-3.5"-4" TYMAR DP, Homemade 4" Exhaust, Modified Fuel System w/VorMax Fuel Filter, 33 gal. Bronco Tank, TYMAR Air Filter, Rockin' S 3-Gauge Pod, Autometer Gauges, Joe Servo IDM, Tru-Cool #4590 Tranny Cooler, Factory Tech Valve Body, 4R100 TC, Dual Wheel Tensioner, & Upgraded Air Intake.
My Webshots
See "Jimmie: The Great White Hunter in Action"
Big Fig is offline
Old 04-30-2008, 08:26 AM   #9 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I have the in bed tire carrier already. I figure modifying the sender and pick-up should not be that hard to do.
It will not happen until June or later so I have time to look around and gather parts.
