Old 04-23-2005, 09:23 PM   #1 (permalink)
My Photos: (60)
Gauge dash pods for '96
Im getting some gauges.
After pondering for a long time, much of it sitting alone in my truck pretending to drive with three 2" plastic bottle caps in various locations [img]/ubbthreads/images/graemlins/blush.gif[/img],
I have decided to go with a triple gauge dash mount pod..........
The problem is all I see is 99-05 dash pods.
Will these pods fit a 96 truck or not?
Does anyone make a pod designed to fit our year truck dash?
Do you know of any pod that will fit, I want to put it on the dash above the radio, its about a 4 3/4" x 9 1/4" flat space.
Thanks.
Steve
FreeFlyFreak is offline
Old 04-23-2005, 09:36 PM   #2 (permalink)
Re: Gauge dash pods for '96
Steve,
I sent you a PM.
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 04-23-2005, 09:50 PM   #4 (permalink)
ThreeStarJR's Avatar
Steve, you are now in the hands of the gauge king, Rick will lead you to the monitering promised land! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Wildman Tunes
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
play it loud!
#3
ThreeStarJR is offline
Old 04-23-2005, 09:54 PM   #5 (permalink)
Posts: n/a
Post deleted by JLester
Old 04-23-2005, 10:01 PM   #6 (permalink)
My Photos: (60)
Have you seen THESE [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
I have seen those, look good, but the problem is my regency conversion truck has a huge long pod up there already, switches lights and a radar detector built in. No room up there.
1996 F350 XLT Dually 2WD, PCM: NAW4, 124K miles, 4.10 LS, Crew Cab. Pulling a 10k lb fifth wheel.
Mods/adds: ATO E4OD transmission using Chevron Drive Train Fluid, Billet Torque Converter, Jordan Ultima 2020 brake controller. Weld Racing Aluminum Wheels, Regency conversion. Cleaned fpr screen. FPR shimmed to average 61 psi. EBPV used as exh. brake. 28K GVW Tranny Cooler with Steel Braided Line. 3" downpipe and test pipe (XC2Z5A212AA cut to fit). 203* Thermostat. Edge Evolution. Isspro Pyrometer pre turbo. SP Diesel SSEB + TCC.
See photos of my truck click here
Old 04-23-2005, 10:37 PM   #8 (permalink)
Aw [img]/ubbthreads/images/graemlins/blush.gif[/img] Jim...
Rick H...
HIS
HERS
Old 04-23-2005, 10:41 PM   #9 (permalink)
what else could i put in the 3 gauge pod?i know i want water temp and oil pressure gauges,how about oil temp? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Air pressure, vaccum, rear/front diff temps, fuel pressure, oil pressure, oil temp (do it BEFORE cooler), trans temp, coolant temp, coolant pressure, intake temp, pyro (dauls would be nice).
I just listed about 2,000 worth of gauges [img]/ubbthreads/images/graemlins/eek.gif[/img]
Rick H...
HIS
HERS
Old 04-23-2005, 10:46 PM   #10 (permalink)
sea97stroker's Avatar
Rick what about the driver temp, you forgot that one, i'm sure the guys could come up with a sender placement location.
LOL
Steve [img]/ubbthreads/images/graemlins/grin.gif[/img]
1997 F350 CC 5 Speed 4x4 , BDP Stage 2's, Wildman Chip, Isspro Gauges, 5 inch stacks, SD Turbo Setup,Banks Intercooler,Tymar Intake, SD Leather Seats. Dyno 427hp/813tq
www.BeansDieselPerformance.com
sea97stroker is offline
Old 04-23-2005, 10:55 PM   #11 (permalink)
Dang Steve, I'm hating the visuals I'm getting on the driver temp location....... [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/sleepy.gif[/img]
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP Fuel system
Wildman Tunes
Caltracs
play it loud!
#3
Old 04-23-2005, 10:57 PM   #12 (permalink)
I couldn't help myself from giving Rick a hard time.
Steve
Old 04-23-2005, 10:59 PM   #13 (permalink)
Posts: n/a
Old 04-23-2005, 11:04 PM   #14 (permalink)
Wonder if you would be [img]/ubbthreads/images/graemlins/grin.gif[/img] while your driving or [img]/ubbthreads/images/graemlins/shocked.gif[/img].
Rick H...
HIS
HERS
Old 04-23-2005, 11:27 PM   #15 (permalink)
My Photos: (60)
The only ones I have found online are Banks dash pods but I cant find any photos of the model numbers Im looking for 63107 63105 63121 anyone have any photos of these?
