gauge pillar ? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 06-26-2007, 08:13 AM   #1 (permalink)
gauge pillar ?
dose anyone make a four gauge A pillar pod for a 1995 psd. and wear do u get one at. thanks
04 F-350 psd 4X4 3 1/2"downpipe, 4"back,
95 F-250 psd 4X4 3" downpipe, 5" miter cut stacks, superchips, 6" lift, 37"s, road master trans
04f350604x4 is offline
Old 06-26-2007, 03:50 PM   #2 (permalink)
johndeere9610's Avatar
Send a message via AIM to johndeere9610 Send a message via Yahoo to johndeere9610
Re: gauge pillar ?
I dont think they do. But it would be nice if they did.
Rusty
1995 F-350, Auto (stock), 4x4, Crewcab, Longbed, 4" superlift, 35" BFG's All Terrains, E12000 Milemarker Winch, 5" miter stacks, 160cc Injectors, Shimmed FPR, Tymar Intake, Tyamr HPX, 7.3L Intercooler , 6.0L Tranny Cooler(Thanks Jon), ISSPRO Guages Trany/Boost/Pyro, Built tranny in garage being built.
WILDMAN NATION
RDRCM# 50
johndeere9610 is offline
Old 06-26-2007, 05:20 PM   #3 (permalink)
Re: gauge pillar ?
ok thanks a lot
Old 06-26-2007, 05:30 PM   #4 (permalink)
Re: gauge pillar ?
You can take a 3 and graff on a 4th using fiberglassing technices.
Time consuming but doable. I just never got around to producing them.
What do you want the 4th gauge for?
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 06-26-2007, 05:31 PM   #5 (permalink)
Re: gauge pillar ?
my buddy gave me a water temp gauge
Old 06-26-2007, 05:58 PM   #6 (permalink)
Re: gauge pillar ?
I would like a 4th so when I go to e-fuel and can have a pressure gauge. or when isspro come out with the new hpo gauge. I dont really like the look of gauges all over the place. so if I could get four on teh pillar it would be nice.
Rusty
WILDMAN NATION
RDRCM# 50
Old 06-26-2007, 06:19 PM   #7 (permalink)
Re: gauge pillar ?
ok thanks for your time
Old 06-26-2007, 09:31 PM   #8 (permalink)
Re: gauge pillar ?
Rusty
You mean like mine?????
[img]/ubbthreads/images/graemlins/blush.gif[/img]
Rick H...
HIS
HERS
Old 06-27-2007, 03:00 AM   #9 (permalink)
Re: gauge pillar ?
Rusty
Rick H...
I didnt say anynames
Rusty
WILDMAN NATION
RDRCM# 50
Old 06-28-2007, 04:25 PM   #10 (permalink)
Re: gauge pillar ?
If there is enough interest we will design one. As a minimum I plan to have one designed and built in our rapid prototyping machine, so I can have one! The tooling charges are pretty steep for mass-producing them though. If you are interested in one please Pm or e-mail me. Since my personal truck is an OBS, we get a little bit of preferential treatment when picking out new projects [img]/ubbthreads/images/graemlins/wink.gif[/img]
I'm also thinking of having a small pod made which fits directly over the steering wheel, with curvature to mate up with the factory dash. Would anyone be interested in such a pod?
Thanks,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 288k miles (Ford rebuilt E4OD at 226k)
10 ISSPRO Performax gauges, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Baby Swamps & Tunes, Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
2000 Jetta TDI - Kerma reflash, Der Chimera Stage II Clutch
1998 S&S 9.5' slide-in camper
33' enclosed tag trailer with 2 doorslammer drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
NRA member and certified firearms instructor
GOA member
IDPA member
MJPliska is offline
Old 06-28-2007, 08:08 PM   #11 (permalink)
Re: gauge pillar ?
Michael, if DP tuner comes out with their chip switch that fits a gauge hole, then the demand for a 4 hole pod is going to go up!
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 06-28-2007, 08:25 PM   #12 (permalink)
Re: gauge pillar ?
i would by a steering wheel pod the min its out there.
jon
1996 F-250 4x4 extended cab 5spd
dana 60 37" Humvee tires, RS 9000 XL 9 way shocks, 5' ladder bars Con OFE clutch working on replaceing all bulbs with leds
swamp injectors, 6 position chip, pyrometor and boost gauge, 4" turbo back exhaust, tymar intake, 17 HPOP, shimmed FPR solid steel front bumper, in bed 100 gallon tank
car 2
1963 ford Thunderbird
work in progress C-6 and mild built 390FE stroked to 445 planned ( shouldn't all engines be about this size)
iowaford is offline
Old 06-28-2007, 08:49 PM   #13 (permalink)
Re: gauge pillar ?
You mean like this one OBS Steering Column Mount
Another Pic in place
[img]/ubbthreads/images/graemlins/grin.gif[/img]
Rick H...
By the way, they are patent pending! PM me for more info.
HIS
HERS
Old 06-28-2007, 08:50 PM   #14 (permalink)
Re: gauge pillar ?
Could you use two, two gauge pods? Maybe a little trimming, but may work.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 06-28-2007, 10:29 PM   #15 (permalink)
Re: gauge pillar ?
PM sent
