Gauges or Tranny Issues
Alright so My trans temp gauge is reading pretty high temps, usually it tops out at 250* which is as high as it goes. I want to know what is wrong and how to fix it. Heres what I've done so far to attempt at making it stay around 140* where it should be.
*Replace stock cooler and hoses w/ (30,000 GVW Flex-a-Lite)
*Changed Temperature Sending Unit
*Checked Ground
My next guess is its the gauge, cause at if i were to leave the truck idling itd read the trans temp at 250* and Ive measure the surface temp of the oil pan when the gauge read 230* and the IR thermometer said it was 115*.
Im so lost when it comes to electronic things, please help! lol
If it dont burn, it aint good!
1996 F250 4x4 S/C LB, 4.10, Tymar Intake, 4" Strait-Pipe, Marsh E40D, 4" Lift, 35" Pro-Comp Xtreme-Mudders on 16x8 Steelies, 190K miles, TW Chip, Rose 160cc injectors, SD CAC, D66, 2" Rear Aluminum Spacers, Dana 60 Front w/ LockRight Locker
On The List: Oil, Tank, Fuel, Lockers, Modular Flatbed
