Gear Question - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-15-2009, 09:19 PM   #1 (permalink)
Send a message via AIM to Whitefiveo
Gear Question
Hey guys im changing out my front gears in my dana 60 just wondering if anyone has any opinions on the genuine gears? Anything bad about them? Anything else you would recomend.
Thanks Brian
96 F250 MBRP Full exhaust, Tymar Intake, Autometer gauges
Whitefiveo is offline
Old 11-15-2009, 09:47 PM   #2 (permalink)
travis23's Avatar
i had a friend that used a set he said they worked really well and if you bought the install kit they warranty them for life did you trash a dana 60
1988 crew cab 4x4 idi in trash can 97 powerstroke engine in and running stong burning atf nothing like free fuel, update pieces of the head gasket laying on the frame stretched headbolt was the cause oops
travis23 is offline
Old 11-15-2009, 09:49 PM   #3 (permalink)
Thanks for the quick answer, no i did a dana 60 swap and my front ratio does not match up with the rear so im doing a swap
Old 11-15-2009, 10:01 PM   #4 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
Tons of guys run the genuine gears brand ring and pinions without a single problem. Just make sure you follow the break in procedure and you will be fine.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline
Old 11-15-2009, 10:10 PM   #5 (permalink)
Great thanks guys, another quick question what were the options on gear ratios in these trucks stock? 4.10 or 3.55 correct?
Old 11-15-2009, 10:11 PM   #6 (permalink)
My Photos: (60)
OBS that is correct.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 11-15-2009, 10:39 PM   #7 (permalink)
Thanks for the help guys
