Old 11-21-2006, 03:30 PM   #1 (permalink)
moonshiner's Avatar
Gear ration and Lift questions
If I wanted to lift my truck a couple more inches to fit 38" would I be better off with a suspension lift or a body lift? Should I buy new springs or should I do a shackle lift?
What is the best gearing for me to use with 38" tires? I like speed and I'm not a big fan of rock-crawling, so whats the best ration?
I remember seeing a chart that delt with the tire size and gear ration a while ago, I just cant find it again.
If it dont burn, it aint good!
1996 F250 4x4 S/C LB, 4.10, Tymar Intake, 4" Strait-Pipe, Marsh E40D, 4" Lift, 35" Pro-Comp Xtreme-Mudders on 16x8 Steelies, 190K miles, TW Chip, Rose 160cc injectors, SD CAC, D66, 2" Rear Aluminum Spacers, Dana 60 Front w/ LockRight Locker
On The List: Oil, Tank, Fuel, Lockers, Modular Flatbed
moonshiner is offline
Old 11-21-2006, 04:22 PM   #2 (permalink)
Briansshop's Avatar
Re: Gear ration and Lift questions
You can pull the 38s w/your 4.10s,but you'd prob like some 4.56s or some 4.88s better.I ran 4.10s for a few yrs,and just changed out to 4.88s.If I did it again I'd go for 4.56s.Randys Ring and Pinion has a ratio chart on their site.I'm not a fan of body lifts but that's just my opinion.
Brian
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,open intake,SD IC,1.0 Housing,Pedestal Mod,Gutted EBPV,dp,5"no muff, Baumann TCS controlled e4od,"I LOVE that thing"!,Baumann VB kit,UCC Custom Billet T/C-VERY low stall speed,Mag-Hytec pan,dual True-Cools,remote filter,3 pos.T/C lock-up switch w/LED,Elec.fans on trans.& engine w/Derale adj.stats,Gauges,Kingpin D60 w/Lock Right,Detroit Locker in the 10.25,4.88s,4" Nat. springs w/ORU-SRK in fr.,crossover steering,10" Atlas springs in rear-no blocks!,Bilstein 5100s,38" PJ Dirt Grips on 16x12" M/T Classic Locks w/Centramatic balancers,Warn hubs,Powerslot rotors,Hawk pads,Can-Back canvas top.
http://s77.photobucket.com/albums/j70/Briansshop/
Just getting broken in, 50,000 miles!
Briansshop is offline
Old 11-21-2006, 05:30 PM   #3 (permalink)
I'd also go with 4.56 w/38's. Are you planning to swap in a D60 into your F250? You'll need a 6" lift and probably cut out fender flares to fit 38's with your current TTB D50 front. I think the best setup would be some 4" lift springs combined with a shackle reversal and a D60 in the front, then some custom lift springs on the back to eliminate the tall lift blocks.
'96 F250 CC SB 4X4, BTS E4OD, D60, 4.10's w/ARB's, 4" skyjacker lift, BFG 37x12.5r17's, Bilstein 5150's, Tymar intake & downpipe, BDP 6 pos chip, BDP Stage 1's, D66 Turbo, 17* HPOP, SD Intercooler, Warn bumper w/M12000, piller pod gauges, CCV mod
Truck
Mtntruck is offline
Old 11-22-2006, 01:22 AM   #4 (permalink)
moonshiner's Avatar
My fender flares have already been cut out, I already have 4" lift springs in the front, So wheres a good place to just go out and buy 4 leaf spring packs? I'm either going to swap out a d60 or d44, cause the 44's are way cheaper, and i dont really do rock crawling.
Old 11-22-2006, 09:34 AM   #5 (permalink)
Nit
a 44 will not hold up with out spending D60 money on it, so jsut go with the D60, that added to your current 4" lift will be fine.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
