Getting truck to sit level - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-27-2010, 03:22 PM   #1 (permalink)
96crew's Avatar
I have installed a set of tuff county add-a-leafs to the front of my truck. They did what was listed and lifted the truck about 1 3/4". My problem is the truck i still about another inch or so from being level. As far as I know the rear of the truck is stock. I installed air bags at same time as the front add-a-leaf springs for when I pull the trailer. Has anyone else had this issue? Or am I just making a bigger deal than need be?
1996 F350 Crew Cab-4x4-5spd-White&Silver- 7.3L PSD-3" dp-Straight pipe exhaust-Gutted EBPV-3 piller gauge pod,egt,boost,trans temp-10kmod-Rhino liner-LMC rear bumper w/lights-custom made cold air intake-Trans cooler-SD IC-285/75/16 Pro-comp AT xtreme-SMFW,South Bend Clutch-Tuff country leveling kit-Firestone air bags-Tymar hpx kit-Air horns-Clear headlight and marker lights-Leer shell-
Other toys
2006 Eclipse Attitude toy hauler
Honda 400ex his & hers
Honda trx70
Yamaha Zinger
Polaris Trailblazer 230
1969 Chevy Nova 1/4 mile 12.34 @ 110mph
1995 Jeep YJ
2011 Ford Flex
96crew is offline
Old 02-27-2010, 08:51 PM   #2 (permalink)
Every I've had has been that way... calls it rake... my truck sits with about 2 3/4" to 3" difference with no load... but put my top on and/or a lite load and it goes to about 1 1/2" to 1 3/4" difference... they put what seems to be a softer initial spring in the rear on some trucks that allow more compression before going to the heavier load springs... at least on 1/2 ton and some 3/4 ton I've never had a 1 ton or greater.
tlp97f250hd is offline
Old 02-28-2010, 09:53 AM   #3 (permalink)
I have a 99 F350 DRW 4x4 that has about a 3 inch diff if not more and would like to level mine. The only time it was almost level was with 2400lbs of concrete in the back. But what's the best way to get the front high as the back?
mr.dunne is offline
