i got the afe stage 2,edge evolution, 3 gauges pyro,trans,boost. What should i get next. looking for fuel economy but want to set the truck up to race when i get enough money (injectors turbo hpop,etc.) any info would be greatly appreciated
Yeah, a downpipe and exhaust made a big difference for my truck, then I would take the money you have left over and buy lottery tickets, and if you win, you will have enough money for the racing part, it never ends, once your hooked [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img] Good Luck
Frank
__________________ http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DIESELDUTTON</div><div class="ubbcode-body">Yeah, a downpipe and exhaust made a big difference for my truck, then I would take the money you have left over and buy lottery tickets, and if you win, you will have enough money for the racing part, it never ends, once your hooked [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img] Good Luck
Frank </div></div>
So so true!!
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
1996 F-250 super cab 4x4 auto 180,000 miles.TS 6 six position chip,4 inch motoblue exhaust,afe stage 1 intake and toyo 285 all terrains.Next is a quadzilla commander!
id do the exhaust for sure, at least the dp. Put the evo in the for sale section and get a chip from beans, get the IC in then do some injectors when you run across some more $. If you run across some good deals or do DIY injectors you could maybe squeeze all that in for "around" $1000.
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake Big_Dan97's Photos
if i get that ts chip now and later on get the injectors or anything else (will i and can i) need to re tune the chip. Should i wait to get the ts chip until everything else is set up. i saw swamp does their own tuning and thats where im looking to get majority of my stuff (turbo,injectors etc.) i just ordered the evolution ill send it back if yall think it will be ok to get the ts chip now.
i c i c what website should i get them from swamp or somewhere else i think black cloud diesel had the setup pretty cheap or do i need to order straight from him
$1000.00 to spend?!?!? You could buy me a plane ticket to your place, I could sit in your garage, drink your beer and watch you work on a project with the remaining $400.00!
Actually, I'd agree with the downpipe / exhaust kit for starters. I found it to be a worthwhile project with great results. Problem is, I was so pleased, it made me spend some more on a few other mods. It is soooo addictive! Best of luck.
1997 Crew Cab Long-Box 4X4 5sp PSD.K&N Intake. Workhorse and then some.
