Old 08-17-2007, 06:57 PM   #1 (permalink)
Got gauges installed today....what are the safe zones for them??
hey everyone,
I had some autometer gauges put on today for boost, tranny temp, and pyrometer. Can you guys tell me what the safe operating temps are for the tranny and the pyro?
Also when driving down the road at say 60mph at a steady speed the boost gauge only shows about 1 lb of boost but when I really get on it I can only get it up to around 6 lbs of boost(without a load on level ground). I was wondering if this is normal? The truck is a 1997 f250 extended cab with a tymar intake and tymar downpipe/exhaust but other than that it is stock.
Any help/advice is greatly appreciated. thanks.
2008 F-250 CC 4x4, b&w gooseneck hitch
leeinmemphis is offline
Old 08-17-2007, 07:33 PM   #2 (permalink)
Re: Got gauges installed today....what are the safe zones for them??
If your pyro is in the manifold not above 1250* if its in the dp Id say 1000* but Im conservative on egts. On boost I think its 20lbs on tranny Id say 200* or less, your boost at 60mph sounds right, I would think getting into it you should see higher than 6lbs but I didnt have gauges until a chip so I dont know what a stock truck would do on boost.
Dan
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 08-17-2007, 10:04 PM   #3 (permalink)
thanks big dan. I'll have to double check where they tied in the pyro. It was around 98 degrees here today and the tranny got up to 180 degrees without a load. Considering the temperatures outside I guess that was ok. Thanks again!
Old 08-18-2007, 03:17 PM   #4 (permalink)
You should probably be seeing in the low teens for your boost pressure on a stock truck.
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
Old 08-18-2007, 09:16 PM   #5 (permalink)
My Photos: (6)
yea 15 pounds at full load on a sticker without a chip.
97 F-250HD Super Cab 4X4
Jasper E4OD, 3.55 gears
Auto Meter Dash Mounted: Trans temp, Boost, EGT, Oil Temp, Oil Pressure.Water temp. Gauges. http://photos.thedieselstop.com/show...t=1&thecat=500
Homemade Open Air Filter, 3 in SS DP, SD, 03 Intercooler. GTS kit. Modified Pedestal, ITP SS HX, CCV Mod, BABY SWAMPS & SWAMPS 6 POS Chip, 17 Deg HPOP, Gutted EPBV, Jasper Stage 1
249,000 Miles, and still going Strong.
TSM Disk Rear Brakes
Cratos is offline
Old 08-18-2007, 11:47 PM   #6 (permalink)
Just to let you know what im running...Granite, i have downpipe and tymar intake, so take it for what it worth, Running 70mph I get 5psi boost and egts are 800 with tranny at about 165.. on level ground with cruise control(no load). If i get on it going up hills ive gotten boost upto 23psi and egt 1100, tranny 180. Just wanted to give you a reference, hope it helps.
BigConz is offline
