Grab handles for obs trucks? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 09-09-2010, 12:55 AM Thread Starter
Anyone have any ideas for grab handles and how to keep it relatively stock looking?
1996 F 250, XLT, 4x4, SC, 14k on NEW 7.3 and turbo, stock.
zak250 is offline
post #2 of 8 (permalink) Old 09-09-2010, 01:00 AM
Have read posts in the past of people using the grab handle from the 99-up trucks for the front passenger. Depending you your interior color, you might find an exact color match. You might try using the search feature to see if you can round up one of these old posts....one even had pictures but it's been a few years since I read it.
'94 F350 4x4 PowerStroke, 5-speed, 4.10 gears, crew cab, XLT, Luk Clutch, ZF-47, Hydroboost, AIC, Max A/C Assist, 95.5 radiator and degas bottle 318,000 miles
'96 F350 4x4 PowerStroke, auto, 4.10 gears, crew cab, XLT, DRW conversion, AIC, 502,000 miles
'02 F350 4x4 PowerStroke, 6-speed, 3.73 gears, crew cab, XLT, DRW, AIC, 223,000 miles
Diesel_Aggie is offline
post #3 of 8 (permalink) Old 09-09-2010, 01:21 AM Thread Starter
Yeah i just searched, I guess Im just looking for other ways to mount it without drilling, one I saw used well nuts, looked good to me. Any other ideas for mounting?
zak250 is offline
post #4 of 8 (permalink) Old 09-09-2010, 01:45 AM
If you don't drill and mount it into something solid, won't it just rip out if someone actually uses it? I'm not exactly sure what well nuts are.
post #5 of 8 (permalink) Old 09-12-2010, 05:54 AM
JMCX's Avatar
My interior is blue and I found some at the junk yard in a Subaru wagon that match almost perfectly. I used one hole that was already there and added another. Just #8 screws into the cab sheet metal. I can hang from them and ten years later no problem.
97 F350 SW CC 4X4 Auto, IDM mod, TW six position, DIY Stage I's, Beans D66 Turbo & 3" DP, 4" straight exhaust, Mobil 1 ATF, Tru-Cool 28k, Fuel filler mod, 99 Intercooler, Open Air Filter, SmittyBuilt stainless nerf bars, Trans-go tugger kit and Billet TC
2011 Silverado LML (work truck), 72 Mach I 552 stroker
JMCX is offline
post #6 of 8 (permalink) Old 09-13-2010, 11:41 PM
mattski's Avatar
Used a grab handle from my buddies '06 on my pass side. Just trimmed the door post plastic to fit and then mounted it with #8 self tapping sheet metal screws. Works great with no problems so far and 200+lb buddies using it. Even the light grey interior plastic is a perfect match even with 9yrs difference! A bit of work to get it to look good but just take your time trimming that's all. Well worth the effort. (At least that's what my wife said)
Mattski
97 F350XLT, CC, SRW ,LB 4x4, 4.10LS, E40D rebuilt with triple disk billet TC & superior shift kit w/sonnax valve, genuine Tymar intake, Diamond Eye 3" DP- 4" back to 5"tip, Stage 1 inj, IDM mod, gutted EBPV, modded pedestal, TW 6 pos chip, BD Diesel Turbo Thruster II turbo, 7.3 I/C, shimmed FPR, Dieselsite 203' stat, Tymar HX, 2 Tru cool tranny coolers, 3"RSK w/X-codes, 5" Icon's, Bilsteins, 315/70R17 Mickey Thompson MTZ's on 17X9 Pro Comps, N-fab steps, Fuel filler mod, Dipricol Optix pyro, boost & tranny temp on A-pillar, Pioneer CD, amp & 8" Pioneer sub, SIRIUS Sat.
SOLD Sep 2014.
mattski is offline
post #7 of 8 (permalink) Old 09-14-2010, 12:40 AM Thread Starter
I wasnt sure if the sheet metal screws would cut it but i guess if its workin great for you guys ill go that way. Well nuts are expansion nuts, drill a hole, put the plug in and when you put a bolt in the plug expands. I saw someone post about mounting handles that way on here.
zak250 is offline
post #8 of 8 (permalink) Old 09-14-2010, 01:54 AM
Anyone have any pictures of the install or installed handles on their earlier trucks?
MilitaryRelated is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
